I was recently checking prices for a new clutch for my 185. Its getting a 205 box so while i was looking down the price lists of TCB in the UK I spotted two clutches listed. Aisin (original suppliers of the GT4 gearbox and clutch) have two clutch/gearbox spline sizes listed - 28.8 and 29.8mm. The 29.8 is the 165 and early 185. 28.8 is the late 185 and 205.
I checked against all other aftermarket clutch people and found everyone else just has the 29.8 specification. So i measured the 205 spline diam and get 28.3mm (28.8 less a little for easy fitting I presume). But throwing in a clutch designed to fit a 29.8 is a fairly large difference and cant be good IMO. This could be the cause of many early failures, noises and rapid wear rates. I'm trying to contact Aisin for 100% confirmation.
Does anyone have a 185 box out, of known year, that can measure the input shaft spline diameter accurately? I'm trying to build up a mini database of sizes to see if its true.
Cheers all!
Cheers all!
