Centre Diff Backlash
Postby coyoteboy » Tue Jan 30, 2007 11:43 am
From what I could see with my car raised, I have a fair amount of backlash in the centre diff - front and rear wheels take a few degrees to begin turning together when direction is changed. Is anyone aware of roughly how many degrees is normal before I start removing shims from the transfer side-gear case to get it reduced. The front and rear diffs have minor amounts of slack as you'd expect, maybe 1 degree or so. I was thinking of matching that.
J
'91 ST185 ATA.Megasquirted, MHG,SSAC 3" DP, fully wrapped 2.75 inch system,K&N,Forge DV, JDM ST205 turbo&transmission,JDM MR2 turbo engine.
http://www.gt4ec.net << The GTFour Enthusiasts Club
coyoteboy
Return to Drivetrain Central
