My hydraulic clutch line seems to be sucking in air somewhere. The problem is I bleed it, it works fine, then I go home. The next morning I'll start up my car, it seems fine, but then progressively gets worse and then by the time I get to work (9 miles) it just sticks to the floor with no more pressure. Bleed it again, works great, then same deal.
I've already replaced the master and slave cylinders with aftermarket units from Autopart International. They usually provide quality parts, but I'm thinking it's gotta be from one of those.
I should also mention that this didn't happen until after I installed the longer slave rod from Speed Source. The only reason I installed that was because I wasn't quite getting full disengagement after installing my Spec Stage 3+. After I installed the rod, I adjusted the pedal out a little further so that it grabbed just right and I thought I was good to go. 2 days later, the pedal went to the floor and the saga began. In retrospect, I should have adjusted the rod first, but I didn't. I'm about to put the stock rod back in, bleed it, and adjust it and see if my problem goes away -- that's assuming that the rod is somehow the reason I'm getting air sucked into the system.
Any other ideas before I do this? Quick replies are appreciated, as I get out of work in about 4 hours and will be doing it then. Thanks.
