running st205 rear diff on st185 possible?
Postby wizzards581 » Wed Feb 14, 2007 2:29 am
somewhere on these forums is said to be a bolt on... meaning st185 axles, shaft all bolts up? what about the gearing? wil it be geared same as st185?
-03 matrix XR
wizzards581
Re: running st205 rear diff on st185 possible?
Postby Conan » Wed Feb 14, 2007 5:42 am
wizzards581 wrote:what about the gearing? wil it be geared same as st185?
In short, yes.
Conan
Postby etantshi » Thu Feb 15, 2007 3:59 am
the gearing is in the front diff/xfer case area. Not in the rear end like other cars. ex Eclipse gsx
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby alltracman78 » Tue Feb 20, 2007 4:41 am
Actually ALL the gearing is in the front case.
The transfer case only steps it down to lower propeller shaft speed, and it is stepped back up at the rear diff.
Postby wizzards581 » Wed Feb 21, 2007 1:58 am
where rear lsd available for the st205? what about fronts.
-03 matrix XR
wizzards581
Postby evo » Wed Feb 21, 2007 2:20 am
st205 were all TorSen LSD rear, open front
1992/ST185
evo
Postby Tazka » Tue Mar 18, 2008 7:56 pm
Sry for bringing up old thread.
Have anyone actually done this? Does it fit perfectly?
I could get st205 torsen. I just want to make sure it fits first...
Tazka
Postby CMS-GT4 » Tue Mar 18, 2008 8:04 pm
I have done it. Its pretty much the same thing as a 185 torsen.
Postby alltracshoak » Tue Mar 18, 2008 9:21 pm
i compared my 205 rear and it looks just like my 185.. and axles wise, it'll bolt on to it..
current:
90 st185
GT4 AWD
rip: 92 st185 @ 178k :(
alltracshoak
Postby Nitro_Alltrac » Tue Mar 18, 2008 9:46 pm
The one I put in my car was supposed to have come out of a 205. It bolted right up with no problems, axles and all.
Mike
92 All Trac - Daily Driver
Nitro_Alltrac
Postby etantshi » Wed Mar 19, 2008 1:11 am
Fits no problems.
André B.
etantshi
Postby Tazka » Wed Mar 19, 2008 8:45 am
Ok thx for quick reply's guys. :)
Tazka
Postby $200GT-4 » Sun Mar 23, 2008 9:51 am
So you're saying all ST205 GT-4's came stock with a rear Torsen?
1993 GT-4 w/FMIC, N/A cams, 3" DP, MBC, AFM tune, and WAI.
$200GT-4
Postby gt4rcdude » Sun Mar 23, 2008 1:45 pm
Yep. Get 'em while they're hot.
gt4rcdude
Postby GTfour@alltrac.net » Sat May 10, 2008 9:10 pm
i'm not sure i get it so bear with me cause i need to know.
IS THE ONLY difference between the 185 and 205 rear diff the torsen LSD in the 205 or the 205 has different gearing?
if u can answer that you may also be able to shed some light on whether or not the argument that torsen LSD's have been rumoured to be less predictable in corners than other types of LSD setups, is true. i am totally clueless when it comes to the rear diff but i was hoping if the torsens had issues if i could just buy a different LSD (clutch type or something) for the 185 rear diff and get better results than switching to the ST205 rear.
GTfour@alltrac.net
