running st205 rear diff on st185 possible?
Postby etantshi » Sat May 10, 2008 9:41 pm
In short:
st185 to st205 : Same "gearing"
Gearing is done in the transmission
Some st185 come with torsen
All st205 come with torsen
They are interchangeable.
No "issues" that I know off, fairly steady unless you are prone to getting wheels off the ground.
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby Nitro_Alltrac » Sun May 11, 2008 12:24 am
Diff case is exacty the same. It is a straight bolt in.
As for the torsen being twitchy in corners, all I can say is I ran HARD to through the Tail of the Dragon with no problems. Personally, I think it actually helps me cornering speed through sweepers. There is a 270 degree turn up onto a bridge on my way to work. The first morning I hit it after putting the torsen in, I notice that something felt a little different. I was running about 10 mph faster that usual and the car felt like it was digging in some.
I don't see where it would be twitchier. It just sends more torque to the wheel that has more traction. Now with a Detriot Locking rear end, I can see where there could be some cornering issues.
Mike
92 All Trac - Daily Driver
Nitro_Alltrac
Re: running st205 rear diff on st185 possible?
Postby Akihero » Mon Mar 14, 2016 7:38 pm
ok so i added the pic of the damage to the thread on my st205 diff i just got is the st185 cover the same as the 205 ? or is there a better fix for this thread issue ?
Akihero
Postby Nitro_Alltrac » Mon Mar 14, 2016 11:36 pm
As far as I know it's the same. Check it to make sure the bolt holes line up but it should work.
Mike
Nitro_Alltrac
Postby AwdGte » Sun Mar 27, 2016 9:01 pm
I'll take it off of your hands, what do you want for it?
Akihero wrote:ok so i added the pic of the damage to the thread on my st205 diff i just got is the st185 cover the same as the 205 ? or is there a better fix for this thread issue ?
AwdGte
Postby CTechBlueDragon » Mon Mar 28, 2016 3:00 am
Its only like 2 threads man just clean it up and use it. Try to break off the dented pieces and clean it up with a tap and your good to go. Way more work to swap a housing I would think.
Just my 02 cents.
CTechBlueDragon
Images: 51
