Gearbox and diff oil
Postby FoRcE FeD GT-FOUR » Mon Feb 26, 2007 6:54 am
wat type of oil do i use in the gearbox and diff in a st185 gt-four?? is it just a synthetics 75-90 lsd oil??? does it have to be lsd??? synthetic?? any one know for sure?
Brad
Rotorua, New Zealand
89 ST185 GT-FOUR
hksevolution@hotmail.com
FoRcE FeD GT-FOUR
Postby Conan » Mon Feb 26, 2007 7:11 am
Use the one that the manual recommends.
Conan
Postby Denver_whiteST185 » Mon Feb 26, 2007 7:18 am
from what ive gotten from the MR2 boards is that 75W-90 GL-4 gear oil is the best for our trannies and diffs.
^Ted^
Denver_whiteST185
Re: Gearbox and diff oil
Postby eddie_gt4 » Mon Feb 26, 2007 7:24 am
ST185 GT-FOUR wrote:wat type of oil do i use in the gearbox and diff in a st185 gt-four?? is it just a synthetics 75-90 lsd oil??? does it have to be lsd??? synthetic?? any one know for sure?
owner's manual is your best friend :smokes:
'90 Toyota Celica turbo 4WD ST185 - ex
'96 Toyota Celica GT-Four ST205 - now
eddie_gt4
Images: 10
Postby T-Trac » Mon Feb 26, 2007 12:26 pm
Denver_whiteST185 wrote:from what ive gotten from the MR2 boards is that 75W-90 GL-4 gear oil is the best for our trannies and diffs.
If you want smooth shifts and dont mind blowing up your transfer case, go ahead and use GL-4. We need GL-5 protection in our gearboxes because of the transfer case that uses the same fluid. Most GL-5 fluids are meant for differentials and do not offer any protection for our synchros. Ideally you want to use a 75/90 fluid that protects for GL-4 and GL-5 so that you can have synchro and transfer case protection. I've been doing quite a bit of digging around and it seems that Castrol Syntrax Universal would be a good match, but you cant get it in the US, so I just ordered some Silkolene Silktran SYN 5 which seems to fit our application as well. I wont know how well it works till I try it.
Use GL-5 Hypoid Diff Fluid in differential, do not use GL-4 in diff. Might as well just put water in it if you do!!
just my $0.02
T-Trac
Postby Denver_whiteST185 » Tue Feb 27, 2007 2:54 am
just my $0.02
Maybe we should see what Subaru's, Evo's, and the like use???
I really don't know much about gear oil though. im glad you posted cause it gave me some valuable info (since im spending around $1800 total on my drivetrain right now)
^Ted^
Denver_whiteST185
Postby grip addict » Tue Feb 27, 2007 4:31 am
i know alot of the subie kids use a 50/50 split of valvoline 80-90 and syncromesh. gives em the quick shift of doom and offers... decent protection..
me? just running with 80-90 "durablend"
i need to warn everyone-
grip addict
Postby db » Tue Feb 27, 2007 5:15 am
grip addict wrote:i know alot of the subie kids use a 50/50 split of valvoline 80-90 and syncromesh. gives em the quick shift of doom and offers... decent protection..
You know what. Maybe we shouldn't use what the Subie guys use, and just see what the Evo guys use. :evil:
Dave
Black 1990 Celica Alltrac
Las Vegas, NV
db
Postby Denver_whiteST185 » Tue Feb 27, 2007 5:17 am
Thats great :D . im posting this question on a subie fourm and EvoM to see what people think...
^Ted^
Denver_whiteST185
Postby T-Trac » Tue Feb 27, 2007 12:24 pm
The facts are:
GL-4: (synchromesh, ATF fluid, etc..) It is great for synchros and smooth shifts but does not offer much protection for extreme pressure and special friction characteristics associated woth hypoid diifs (our transfer case). That is why most high power cars here running this fluid shift great but blow up their transfer case.
GL-5: (Most Differential Fluids) It is great for Differential protection, extreme presure, friction modifiers etc.., But it does not offer any synchro protection and some actually eat synchros, as in the chemical base reacts with the synchro material (brass or whatever) and reduces its lifespan. That is why most people running strictly GL-5 have grinding issued, but never a blown transfer case.
Ideally you want the best of both worlds. There are fluids out there that protect for GL-5 and GL-4 to offer us exactly what our trans needs. People who mixing synchromesh and diff fluid are in essence providing protectoion for GL-4 and GL-5, but I dont think this is the best way of doing it. Do the two oils "blend" together or do they separate like oil and water? Do all of the chemicals in the two fluids remain inert or do they react with one another and change chemical composition? :shrug: There are alot of unknowns when mixing two arbitrary fluids.
To each is own, you make the decision
Just my $0.02
T-Trac
Postby gt4tified » Tue Feb 27, 2007 1:04 pm
Amsoil severe gear is the shit....but @ $15/quart it will stay on the shelf. I've used mobil1 75W-90....okay but not good for the synchros.
Going to Belray Hypoid full 90 body now...
gt4tified
Images: 5
Postby Denver_whiteST185 » Tue Feb 27, 2007 4:58 pm
Heres my two threads.
http://forums.evolutionm.net/showthread.php?t=254045
http://www.awdpirates.net/phpBB2/viewto ... highlight=
the misubishi guys are saying that we should use Redline MT90 GL-4 and diaqueen (mitsubishi oem diff fluid)
http://www.lancershop.com/customer/prod ... t=0&page=1
^Ted^
Denver_whiteST185
Postby T-Trac » Tue Feb 27, 2007 6:52 pm
Denver_whiteST185 wrote:Heres my two threads.
Just by reading the description of the lancer fluid, I can see that their transfer case fluid is separate from their transmission fluid, therefore you should disregard any transmission fluid advice from them because their application is completely different from ours! I dont know how subaru does their drivetrain, but if the transfer case fluid is separate from the transmission fluid, it doesnt matter what they have to say because we have to protect both the transmission and transfer case with one fluid. If I run Rotella oil in my diesel, should you put it in your engine? No, they are different applications that require different types of protection. We can compare our rear diff to theirs and use similar fluids, even though most of ours are not LSD. :( What am I up to? $0.06? :wink:
T-Trac
Postby FoRcE FeD GT-FOUR » Tue Mar 06, 2007 5:26 am
so it needs to be a gl-5 or higher rated oil am i right? so i can use a gl6 rated oil? also does it have to be LSD? thats wat i want to know. also wats better in the diff? a 80-90 or a monograde oil???
Brad
89 ST185 GT-FOUR
FoRcE FeD GT-FOUR
Postby T-Trac » Tue Mar 06, 2007 1:41 pm
ST185 GT-FOUR wrote:so it needs to be a gl-5 or higher rated oil am i right? so i can use a gl6 rated oil? also does it have to be LSD? thats wat i want to know. also wats better in the diff? a 80-90 or a monograde oil???
Ideally you want a fluid that says that it protects for GL-5 AND GL-4 or mentions transmissions, synchros and differentials in the description with a GL-5 rating. Very few fluids out there say this. I dont know anything about GL-6. I am not sure about the fluid requirements of a torsen diff vs. a LSD, so I am not sure if the fluid has to be LSD rated, but it wouldnt hurt to use one that is just to keep your bases covered. Diff fluid 80-90 or just plain 90 :shrug: I doubt you'd ever notice the difference.
T-Trac
