RAV4 2.0 close ratio gearbox into GT4 ??
Postby 4V6 » Sun Sep 09, 2007 7:36 am
V6 isnt an interference type engine. :)
4V6
Postby CMS-GT4 » Sun Sep 09, 2007 4:04 pm
How smooth is the shifting on the RAV4 box? I am most curious about the syncro situation. I am not as worried about the power upgrade cause if I do the mod, its cause I have maxed out the ct20 and have not plans on getting anything bigger.
Postby ummmiono » Sun Sep 09, 2007 9:50 pm
as soon as i can afford the open class rallies im all over this.
88 red st165 rally project, still awaiting funds
98 milano red integra gs-r currently in rehab
06 cbr600rr
Colin McRae 1968-2007
"straight lines are for fast cars, turns are for fast drivers"
ummmiono
Postby CMS-GT4 » Mon Sep 10, 2007 5:20 pm
I was recently told that the rav4, alltrac and is300 all share the same part number for rear lsd. Anyone want ot verify this? maybe all that needs to be changed is the gear in the rear for ratio rather the whole pumkin.
Postby ummmiono » Mon Sep 10, 2007 10:18 pm
that would be good to know.
06 cbr600rr
ummmiono
Postby 4V6 » Wed Sep 12, 2007 8:25 pm
The shifting experience on the ravbox is pretty much the same as the alltrac, and so it should be as the two share an uncanny resemblance and utilise similar shifter mechanisms ( external).
Apart from the lower top speed youd be hard pressed to know it had been swapped.
4V6
Postby ummmiono » Wed Sep 12, 2007 11:30 pm
the answer is probly in your links but i only read the original. did you finish the turbo setup? any updates? if you still own it is it faster than a 3sgte powered car?
06 cbr600rr
ummmiono
Postby 4V6 » Thu Sep 13, 2007 6:27 am
Still engineering the turbo install.
Biggest buttache so far has been that rear bank manifold but ive managed to package it all in down the back now so its not too far from being screwed back together. :)
4V6
Postby ummmiono » Thu Sep 13, 2007 9:38 pm
awesome.
06 cbr600rr
ummmiono
Postby tybrinturbo » Thu Sep 13, 2007 9:39 pm
i use the stock diff with cusco lsd for the rear,
my tranny is the firts year toyota rav4 with button for lock the center diff.
i swap the front diff and the transfer case for gt4 case.
st185cs rally car
st205 wrc
audi rs6 2004
tybrinturbo
Postby ummmiono » Thu Sep 13, 2007 9:42 pm
so your center diff is either locked or open like the early st165's? no viscous?
06 cbr600rr
ummmiono
Postby tybrinturbo » Fri Sep 14, 2007 4:39 pm
i run the diff with viscous , normal mode
st185cs rally car
st205 wrc
audi rs6 2004
tybrinturbo
Postby ummmiono » Sat Sep 15, 2007 2:39 am
thats interesting, so in open mode its like the stock all-trac diff but when you push the button its fully locked?
06 cbr600rr
ummmiono
Postby tybrinturbo » Sat Sep 15, 2007 11:40 am
no , i not have the button
st185cs rally car
st205 wrc
audi rs6 2004
tybrinturbo
Postby stealthgtfour » Sat Sep 15, 2007 8:34 pm
no more rav t-case = no push button center diff
now its just a close ratio alltrac box
someone should figure out how to do that push button awd lock with
viscous coupling that would be sweet
Mark
93 honda accord(33mpg and 300k mi)
95 miata autoxer
88 165 evo killer(not 33mpg)
in order to finish first, first you must finish.
"I'm not drifting, its oversteer!"
stealthgtfour
