How in the !@#$ do you put the gearbox back on?
Postby Simba » Mon Oct 15, 2007 2:54 am
Well, day three in my quest for a twin plate clutch. Went smoothly enough up to the point of putting the damn gearbox back on. I've followed the BGB as closely as one can with a ~350 pound lump of metal, using two engine hoists, a floor dolly, and all manner of physical pain. Damn if I can get it back on.
Who has some pointers, and hopefully photos of the correct angles involved?
First person with meaningful insight gets a case of beer. Anyone in the tri-state who wants to put the #@$%@ing thing back on for me gets $500. (Yes, I'm serious).
Lots of fast, loud things.
Simba
Postby RWDragoon » Mon Oct 15, 2007 4:16 am
Well iv never done a alltrac myself yet, but I have done many other types. Make sure the clutch discs are totally aligned and that you can install the alignment tool without any difficulties and that it will go smoothly in and out. If you attempt to install the transaxle and fail it can slightly move one of the discs and stop the trans from going in so check after every attempt to make sure everything is aligned(I assume your clutch came with an alignment tool) apply a small amount of grease or anti-size to both the internal splines of the clutch discs and the external splines of the tranny hub this will aid in installation as well as keep things freely moving while in use (don't use alot though or you will contaminate the clutch disc's) The actual installation is always a tricky ordeal. 9/10 you should be able to fully install the transaxle to the engine without using bolts to "suck it up" by just man power.Lots of wiggling and pushing are required. There are the occasional times in which I have used bolts but only do it if the only thing stopping complete engagement is the dowel pints but use extreme caution if this method is done incorrectly you will damage something!
Another trick I have used is to use cut off bolts or studs to "hang" the transaxle. Use long like 4-6" studs and install into the engine bellhousing to help align .
Hopefully this helps but its very hard to describe. Doing them is definitly an experience based ordeal.
RWDragoon
Postby BoostedBlueToyotas » Mon Oct 15, 2007 8:18 am
We needed 3 people to get mine on, but 2 would have been plenty IF we
had checked to make sure that the clutch disk slides easily onto the input
shaft of the transmission before installing the clutch onto the engine. Ended
up having to lightly file the splines of the clutch disk so it would slide on. Then it took 2 minutes to do. Of course two of the people helping me were
mechanics and weighed more then 135 lbs (ie.. I kept the motor in place
while they lifted the tranny).
Tim Plessing
Columbia, MD
BoostedBlueToyotas
Postby sikx5 » Mon Oct 15, 2007 11:51 am
Ive done this a few times on my car now. The twin plate really is a bitch to line up, no other word to describe it.
Ive done it with two other people + myself. Engine on engine hoist, situated on flat and straight, so its dangling there perfectly straight and upright.
I first used my old clutch spline from my destroyed gearbox to perfectly line the plates together. Worked like a charm. Then two mates picked up the gearbox, while i held the engine in place, it just simple slipped on. It required a few love tap from a rubber hammer, but as the plates were aligned perfectly i had nothing to worry about.
Too bad im not in in your area :lol: otherwise im sure i can get that badboy on.
What clutch did you go for btw?
Goodluck!
sikx5
Postby turbo4wd » Mon Oct 15, 2007 12:15 pm
Provided you already have the engine / tranny lined up on the shaft already..
With the engine in the car,and hanging off the passenger side mount, I had a friend on the floor bench press the tranny up and down while I was kicking it in from the side. Took some doing, but it worked like a charm.
With the engine out of the car and on a hoist, I basically did the same thing by pulling the tranny up with my hands while at the same time pushing it into the engine with my body. This was much harder since youve got the engine moving along with the hoist, but it was the only way I could do it.
Dan
Undercover Moderator
turbo4wd
Postby saved_1992 » Mon Oct 15, 2007 12:21 pm
well the best way i have found to do it is
put the engine on end straight up and down (crank pulley flat on the floor with the flywheel pointing up, then the tranny comes down from the top.
gravity will be your best friend, have done this way 3 times, has worked like a charm every time
mike
omaha,ne
1988 a driver (RED) sold
1992 the keeper (RED)
1993 sold to 2of81 (RED)
saved_1992
Postby Denver_whiteST185 » Mon Oct 15, 2007 1:04 pm
saved_1992 wrote:well the best way i have found to do it is
+1. did it this way, and it works so much easier. it was a pain in the ass anyways, but it worked
^Ted^
Denver_whiteST185
Postby Sifu » Mon Oct 15, 2007 3:57 pm
Missle silo time!
Other angle.
This is the hardest part. Making sure that this clears. As you can see there was a lot of fighting w/ all that scraping and getting stuck. You should try to twist and be very careful not to have any fingers getting pinched.
Basically let gravity do the work. Put a piece of carpet on the ground and lay the engine flat on the cam cover side. Take off your powersteering idle valve/bypass valve as those are made of plastic and break easily (replacement is like $80 for the bypass valve, you know, Toyota prices). Carefully lift up the tranny and manuever it over the tranny shaft.
Drop it and twist. Sometimes it's easy to get some rope and put it in the screw holes so you can angle that but I've always been able to drop it onto it w/ no problems. When you can get a screw through the bolting points then do so leaving some slack. Manuever that beast carefully and slowly. It will drop into place.
BROKEN! BUT NOT BEATEN!
2005 Scion tC FW21
1985 AW11
1987 AW11
Sifu
Postby RedCelicaTRD » Mon Oct 15, 2007 10:03 pm
Dear hell! You beat that trans up!
+1 for doing it that way though. Thats 3 times for me doing it that way.
Postby etantshi » Mon Oct 15, 2007 11:28 pm
etantshi wrote:Unfortunately no. I live in GA.
I had written this long post about how to help getting the engine and tranny lined up, but it was deleted after the board crashed. So I'll try it again.
If they're having problems getting the tranny and motor mated up then they should do a couple of things I learned when I used to pull this motor.
1st: make sure all brackets have been removed from the back side of the motor. This includes the motor to tranny brace near the knock sensor and the pass axel area brace near the ps pump. If you leave these on it will make it near impossible to line up the tranny and motor as they will get int the way.
2nd: the way I evenutally learned how to do this was to allow the tranny to lay flat in it's natural position on an elevated platform. Something like a dolly or a crate or something that will keep the tranny flat (tranny jack works great), but keep it off the ground. About 8" of clearance or so should be enough to allow you to move the motor around and get it in the position you need without worrying about the motor hitting the ground and giving you more range of motion when trying to line things up.
3rd: when go to put them together I lower the motor down to meet the tranny. This seems to be easier for me because as the motor slowly lowers you can move it left to right to get it around the xfer case. I use a cherry picker to lower the motor and slide it towards the tranny.
4th: once the clutch assembly is in the general area of the imput shaft of the tranny I run a smal but strong nylon rope through the front side bolt hole of the block and the corresponding hole in the tranny. kinda hard to explain, but you put the rope in just like you were putting in the bolt that holds the tranny and motor together. tie one end of the rope in a loop and thread the other end through that loop. The idea is when you pull the rope tight, it'll pull the tranny and motor closer together and help get it lined up properly. As you pull the rope, you can jack the motor back up, wiggle the tranny (since it's not fully on the ground, but on an elevated platform), and evenutally it'll get close enought to where you can thread one of those long bolts in. Once you get one bolt started, you're good to go.
Hope that helps. I've perfected this method and have gone from mating the tranny in 5 hours to mating it up in about 20 minutes.
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
Postby Simba » Mon Oct 15, 2007 11:32 pm
Jeeez. Four hours later, using the "missile silo" method, I finally got the bitch on. One caveat for multi-plate clutches is that the splines in the disk hub are much longer, and hence have to be aligned perfectly, or no go. The spec I put in a year or so ago was far, far easier.
For those who were wondering, it's a HKS:
Simba
Postby etantshi » Mon Oct 15, 2007 11:35 pm
Missile silo method. lol That's a good one. I'm going to have to use that 'terminology' next time. lol
André B.
etantshi
Postby Corey » Tue Oct 16, 2007 12:34 am
NICE SHOP!!!
:shock:
Corey
Images: 50
Postby stevo27 » Tue Oct 16, 2007 1:36 am
Corey Darling wrote:NICE SHOP!!!
:shock:
um yea that is awsome is that yours??? :shock: :shock:
No longer a member of the AWD club
just a powerglide and rwd for me
"breaking records and breaking parts go hand in hand"
stevo27
Postby Sifu » Tue Oct 16, 2007 2:41 am
Snap Simba. You're making me envious since I've yet to install my HKS twin disk. BTW if I send you a pic of the throw out bearing can you confirm it? It seems that HKS isn't helping me much. Looks great man and hell yah nice shop!
You know you're in good shape w/ a crowd like that...
And yeah, when you're the only person wiggling, wrasslin', drop kickin' it then you should be happy that it's not going to break if it's mishandled a bit...
2005 Scion tC FW21
1985 AW11
1987 AW11
Sifu
