How in the !@#$ do you put the gearbox back on?
Re: How in the !@#$ do you put the gearbox back on?
Postby Killtodie » Tue Jan 15, 2013 3:57 am
MWP wrote:So if doing the missile silo method, how do you guys avoid damaging the end of the engine (timing belt cover, etc)?
User an old tire I supposed. Just make sure it dont tip.
1988 Chrysler Conquest
1988 Toyota Celica All-Trac
Killtodie
Postby DeeCee » Tue Jan 15, 2013 6:01 am
on my st205, the distance between cam cover and crank pulley is 50mm.
We laid some carpet down, tipped the engine, rested the crank pulley on a piece of 18mm mdf under the carpet and then rested the cam cover on a plank that was wider that the cam cover to distribute weight which was 18+50mm high.
Scary thing is to tip the engine on its side without damaging the oil pan. We doubled the carpet to provide a rolling surface.
then we hung the transmission over with an engine crane and engine leveler, got it about right and placed the shaft into the plate. Then we lowered it down and it got stuck on the mounting boss on the case.
I grabbed the angle grinder and got the guys to hold it while I ground the mounting boss off.
We then went again and it was a little stuck. Jonno rotated the transmission a little and knocked it and it went straight on as the shaft must have had to rotate a little to get it in line - and it came down fast due to gravity!
Do not put your fingers between block and gearbox when taking slack off crane!
The mounting boss is the main issue I had. It interfered with the transfer case no end and gave me multiple issues.
Failed way - as you can imagine, I was pissed off with it trying this way for hours.
Missle Silo:
Angle Grinder:
DeeCee
Postby 4rsnduction » Tue Jan 15, 2013 6:34 am
Thanks for those pics :notworthy:
4rsnduction
Postby DeeCee » Tue Jan 15, 2013 7:00 am
happy to help
DeeCee
Postby phattyduck » Tue Jan 15, 2013 5:10 pm
The transmission needs to be rotated up/CCW (towards the intake manifold) along the axis of the crankshaft until just before it engages the dowels. At that point, you can rotate it down in line with all the holes/pins/etc and start bolting it up. Otherwise you will run into block parts like shown above.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby Ironchief » Tue Jan 15, 2013 6:43 pm
Using the missle silo method you just need about 3 strong guys to manhandle the engine so that you dont wreck or bend the crank pulley when you flip the engine to get it onto the ground and also when you flip it back upright after you mount the transaxle. You can't just roll it back down or else it may bend the pulley.
1990 CDM All Trac
Ironchief
Postby Killtodie » Tue Jan 15, 2013 7:01 pm
Damn, that looks more complicated than how I did it. 4 hours of swearing and manhandling it till it slipped back in place with two jacks
Killtodie
Postby rallygarage » Tue Jan 15, 2013 7:20 pm
thanks for pics.
rallygarage
Postby msanders2 » Sun Nov 17, 2013 10:43 pm
Honestly the hardest thing on Earth to do, is mount the trans back on. I have done this twice. Each time taking about 3-4 hours. Trust me, it dont get any easier lol. I always take the transfer case off the transmission. Rotate the transmission, put it almost on the dowels, then re attach the transfer case. I have found this to be the "easiest" way.
msanders2
Postby MWP » Wed Nov 27, 2013 10:21 am
I did it this way a while ago... it was easier than i thought it would be.
Took about 90mins and did it by myself.
I used an engine crane to put the engine on its end, then i used the engine crane to drop the gearbox onto it.
Once the gearbox was bolted down, i then used the crane to pick the lot back up and set it down the right way up.
The engine crane leveler thingie is worth every $$.
It would have been far more difficult without it.
Postby Meurz » Thu Nov 28, 2013 7:55 pm
^ Sexy engine is sexy
Turbocelica.nl
Meurz
Postby JRWperformance » Mon Sep 05, 2016 6:29 pm
I would like to thank the people on this thread. I just did a clutch on my ST 165 and there was no way in hell the trans will go back on the traditional sideways direction. I set my motor on the crank pully and lowered the trans with an engine crane. 1000000000 times easier with this method. Now I'm off to my work to finish the project and drive my celica for the first time.
88 Celica Alltrac
78 Honda GL1000
04 Volvo S60R (Now Dead)
91 VW Jetta Turbo Diesel
JRWperformance
