I had an oil leak in the oil pan, and by the time I replaced the gasket some oil already sneaked it's way in through the clutch inspection plate. The clutch isn't slipping, so I was advised to pretty much ignore it until I decide to put in a lightweight flywheel, or find some other reason to remove the tranny.
Naturally, I can't ignore it after seeing it all gooked at the bottom like that. Is there anything I can do right now to clean it out? I may not be getting any slippage now, but who knows what tomorrow will bring.
