etantshi did you read my description of viscous coupler operation in the rwd thread? barring an actual breakage inside the VC they don't ever wear or break down. The fluid does though.
Viscous couplers operate under the fact that a fluid resists differences in motion within that fluid. The degree of a resistance to differences, also known as shearing, is a fluids' viscocity. Viscous couplers use a fluid that is very resistant to shearing so it is quick to transfer rotational acceleration throughout the fluid. Think of our VCs as an enclosed tube filled with a fluid of decent viscosity with a pinwheel inside each end and the shaft of the pinwheel protruding out like an input shaft. If we spin one pinwheel the fluid within the tube will begin to spin and shortly there after will cause the other pinwheel to turn because the churning fluid forces the other pinwheel to churn in sync with it. This is disregarding the friction of the pinwheels' bearring and the fluid against the tube's walls. Now if we changed the viscocity of the liquid to something thinner, less of the turning power will be transfered to the other pinwheel because the fluid is less resistive to the shearing within itself.
The way in which our VCs fluid insures that it is very resistive to shearing and thus able to transfer high torque is two fold. One the pinwheel like devices are VERY close to each other, and two the fluid contains within it what are called long strand polymers. These are microscopic elastic like polymer chains that cause the fluid to be almost weaved together and thus very resistive to shearing.
These long strand polymers are what fail over time. Slowly they lose their eleasticity and begin to break apart becoming shorter and shorter till there are so few "long" ones left that the fluid loses much of it's original resistance to shearing thus becoming much less viscous.
This is a good thing. This means that the fluid can be replaced and much of the original ability of the VC can be realized as long as the internals never become damaged(which is hard to do, but possible, considering the fact that they are not mechanically connected).
Some people may report a feeling of the VC acting like an open connection because a mechanic or other party replaced the fluid with the incorrect fluid or really old fluid. That is solved simply by replacing again with the correct fluid. Limited Slip Differential fluid for viscous LSDs is the same fluid for the most part. Check with toyota on that one. They still use viscous LSDs in their trucks.
