I finally replaced the clutch in my car. After running a few long hard AutoSlaloms (3 kilometer courses on airstrips) in addition to the abuse of learning how to deal with AWD and 118000km the stock clutch and pressure plate were done. I drove it for a while after it started slipping but it was finally too much. Initially it would just slip in high gears when you pressed the gas, eventually I would lose speed on hills unless I down shifted. I took a look after it was out and the clutch was down to rivits, a gouge worn in the pressure plate, and they had to machine a fair amount off the flywheel. I unfortunately didn't do the work myself But I needed the car done quickly (Shop did it in 12 hours dropping the engine about 8-10 inches and they did VERY good work. Need something done in Halifax, NS and I would recommend them)
I ended up with a Bully Stage 3 clutch. http://www.bullyclutch.com/stage3.html I like the fact that it has the high grip surfaces while still keeping the sprung hub. So far its not too bad, but I'm still within their recommended 1000km break in period. The car is trickier to take off slowly and I stalled it the first time I tried to drive it at all (A few times since too) but it is hardly undrivable, already I can drive it smoothly back and forth to work with only the occasional letting out too quick. So much better then the slippy stock clutch. Apparently the shop puts these on lots of local subarus and VW TDIs, so lots of cars with awd and high torque. The pressure plate is pretty heavy but easy to daily drive. The only day I've had trouble was after a workout of running up and down a steep hill over and over for an hour, my legs were shaking just standing or walking and it was VERY hard to keep the clutch in and I would put it in neutral and use the ebrake at intersections... But it could still be driven. Now to finish breaking it in and take it to the track!! :evil:
I do have a few small issues though. I do have trouble getting into first sometimes. It seems like the clutch isn't completely disengaging. If the car is idling in neutral it sounds like the clutch it touching and chattering a little as well. The clutch only disengages if you push the pedal completely to the floor and has a very small range of being engaged or not. Any suggestions to solve any of these issues? The one I am most concerned about it if the clutch is still partly engaged when I press the pedal down. Would adjusting the pedal up or adding a longer slave cylinder rod help either of those?
