Rav4 close ratio gearbox info
Re: Rav4 close ratio gearbox info
Postby built2run » Fri Apr 15, 2011 6:13 am
nice what year is that first gear ratio from? also i want to find a good final drive thats not too low
ST165, black: parted and gone
ST165, white: sold to friend
built2run
Postby bozo-merlin » Fri Apr 15, 2011 7:07 am
It's a 93 with LSD but as far as i know LSD not matter
from 9112 to 9908 1st and input shaft are the same on E153F so 2nd is same ratio (it's only a synchro mod in 93)
Jérémy
ex 91 RHD ST185 - 2.94kg/BHP
93 RHD ST185 - 2.71kg/BHP
98 RHD SW20 NA
bozo-merlin
Postby Hic » Tue Apr 26, 2011 10:49 am
there is only one question.
if we could fir diesel gearbox to the celica, that is great! anybody?
Hic
Postby built2run » Thu Apr 28, 2011 4:19 am
lol what for? even a good condition e50 will hold 600 whp
built2run
Postby Hic » Wed May 11, 2011 10:08 am
since i will have more than 800hp, I want my gearbox to be LONG, not short.
I want to cruise 200km/h at 4000, and not to listen to roaring engine.
That's why :D
Hic
Postby BNZ » Wed May 11, 2011 12:25 pm
This topic is about SHORT ratio gearboxes :owned:
Street ST185
Rally ST165
HillClimb Renault 5 GTE
BNZ
Images: 31
Postby Gniady » Thu May 19, 2011 7:43 pm
\It works fine -last 2 year. - Need foto - write rgniadek2o2.pl
I put final drive 4,933 - 74/15 - to bearbox from celica E56 Viscus LSD.
Gear in E56
1 - 3,538
2 - 2,045
3 - 1,333
4 - 1,028
5 - 0,820
+ final 4,933 -
Gniady
Postby CMS-GT4 » Thu May 19, 2011 7:55 pm
I am interested in your mod, but I can not send you an email. It does not allow me through gmail.
Postby Gniady » Sat Oct 08, 2011 2:29 pm
Gniady
Postby RoAdbOy » Tue May 29, 2012 5:11 pm
UPDATE!
i did not want to make a new thread for this,
now, i must change my synchros or buy a new gearbox for my ST185.
but after reading all topics about the RAV4 gear ratios, i decided to go with it, if i find a cheap one here :)
now:
if i buy a E250F RAV4 complete gearbox;
- is it really a direct bolt-on to my st185? or must i do a modification anywhere to fit the gear box?
- can i use my exedy clutch from E151F in the RAV4 gearbox?
otherwise i know all E series gearboxes are durable, i don't worry about the durability.
has anyone tried it before in a st185?
[IMG]http://i.imgur.com/emTLn.jpg[/IMG]
Mehmet Ali Ovacikli
istanbul / TURKEY
zürich / SWİTZERLAND
RoAdbOy
Postby tubasteve » Wed May 30, 2012 2:01 am
RoAdbOy wrote:UPDATE!
now:
i herd somewhere this trans wont hold up to the abuse of the turbo banging engine. forgot were i read that. and the 4wd unit isnt as strong either.
again i forget were i read this!!!
neat idea.
-jr
tubasteve
Postby RoAdbOy » Wed May 30, 2012 4:31 pm
thank you for the info tubasteve :)
of course a E151F is more durable, but i think the E250F should last 300-350hp's too?
and for a car with that sort of short gearing is 300hp more than enough... not? :)
and as info:
i talked to 'Batman722' from RAV4 community (rav4world.com) and he has down before a 3sgte swapped rav4 with E250F gearbox.
i asked all my questions and he says:
- the E250F is a direct fit transmission for the 3SGTE and the 3SGTE clutch will fit too
Mehmet Ali Ovacikli
istanbul / TURKEY
RoAdbOy
Postby tubasteve » Wed May 30, 2012 6:44 pm
When browsing for my clutch i read that too.
If i wasn't already tapping into junes budget today...i might have given this a look.
tubasteve
Postby aus jd 2703 » Thu Nov 28, 2013 5:28 am
has any one fitted the rav4 final drive into a gt four gearbox yet? will it fit?
aus jd 2703
Postby built2run » Thu Nov 28, 2013 9:23 am
Honestly I doubt the people that say a rav4 box won't hold abuse from a high power 3S-GTE if the people posting these things don't make more than stock 3S-FE hp. Sure old tired and mistreated transmissions will break even at low hp, doesn't mean the same box well treated with proper fluids and fluid levels will fail under high hp stresses.
built2run
