Trans+transer case
2RM
New member
Finising up my motor and trans swap :) All I have to do is to put new fluids in now. I cant remember does the trans and transer case get filled up from the transmition fill plug or the transfer case got a separate one?
etantshi
Moderator
You can fill both from the tranny fill plug. There isn't really a true easy access fill plug per se, but you can use the reverse sensor and/or the breather plug to fill the tranny. Just be sure to remove the tranny fill plug so you can see when it starts to pour out and you will know when it's full.
Top
