someone know if 3sgte 2 et 3 geneation use de same flywheel and clutch
C Chart45 New member Mar 2, 2008 #1 someone know if 3sgte 2 et 3 geneation use de same flywheel and clutch
C Corey Active member Mar 2, 2008 #2 Yes they do. But here is a discussion on the Early 2nd gen tranny, and the Later 2nd Gen Tranny. Apparently the input shafts are slightly, slightly different. But i dont think enough to cause any issues with clutch fitment. And i cant seem to find any clutches on the market which are specific to the early/late ST185 http://www.alltrac.net/phpBB2/viewtopic ... 22&start=0 Cheers Corey
L Luni New member Mar 26, 2008 #3 Theyre all the same. At least they are in the MR2 world. And we all use the same engines. Our transmissions are even derived from each other too, so Id say any 3SGTE clutch you get should fit.
