Rear diff options...real LSD's...
Postby gtfour77 » Fri Aug 22, 2008 5:13 pm
Ok, I found it...this is what I meant...
http://i32.photobucket.com/albums/d38/s ... tch004.jpg
CMS-GT4 wrote:I am not sure if we are talking about the same part. I do not think welding will help. The issue is The mount is rubber and tears. I am surprised yours is still intact since they normally tear under regular driving. Its the cushion behind the diff with a rubber center that has a plate in the middle that bolts to the diff.
The cheapest solution is to take the mount, if the rubber is not torn, and fill it with poly. It becomes solid, but its still a little more flexible than solid metal.
They used to offer rear poly mounts in the 90s for the gtfours. But the simpler way is just to pour it yourself like they do when they make DIY sold motor mounts.
Martin V.
Toyota Celica Alltrac 561 SM
Toyota MR2 Turbo 35 SSM
gtfour77
Postby CMS-GT4 » Fri Aug 22, 2008 5:21 pm
I see what your doing. That works too. That should be much easier to do than fill it with poly. And you can always take it off if you don't like it.
I guess once you do it, tell us if you can feel any difference. I am curious if your car is so far over the edge, if you can feel super minor changes or if its so sensitive now, you feel any change.
Either way, I bet driving that car is a very lively experience.
Postby gtfour77 » Fri Aug 22, 2008 5:42 pm
CMS-GT4 wrote:I see what your doing. That works too. That should be much easier to do than fill it with poly. And you can always take it off if you don't like it.
For example... I was able to "feel" a 1/2 degree change in rear camber during an event (it slipped due to camber bolt and paint chips between the shock body and spindle)....I got home and I confirmed it with a camber gauge... you can also feel when the tires start to get too hot, 2 psi tire pressure change...etc... so yes, I am pretty sure it'll be easy to feel the welded cushion... :)
Martin V.
gtfour77
Postby gtfour77 » Fri Aug 22, 2008 6:49 pm
CMS-GT4 wrote:Either way, I bet driving that car is a very lively experience.
You should come down sometime and go for a spin! That's an open invitation with a place to stay if you decide to come down for a weekend...:wink:
Martin V.
gtfour77
Postby CMS-GT4 » Fri Aug 22, 2008 6:59 pm
Someday, I will. We need to get IllGt4 to come down too.
Postby gtfour77 » Fri Aug 22, 2008 7:04 pm
CMS-GT4 wrote:Someday, I will. We need to get IllGt4 to come down too.
You mean Chris? I come up his way all the time (Steele Cities Region) , maybe we can all meet again at BeaveRun sometime...
Martin V.
gtfour77
Postby CMS-GT4 » Fri Aug 22, 2008 7:32 pm
Yeah, Chris H. Does he still live in Denver? He does not seem to post on here much anymore.
Postby syko says » Fri Aug 22, 2008 8:09 pm
If CMS doesnt take the invite; I will! hahaha.
Aloha,
Evan
syko says
Postby CMS-GT4 » Fri Aug 22, 2008 8:13 pm
Here is the c-one diff mount.
You might want to keep the invite to PMs. You get get the whole forum showing up at your house. ;)
Postby gtfour77 » Fri Aug 22, 2008 9:06 pm
CMS-GT4 wrote:Here is the c-one diff mount.
Haha, I don't think my car is that special, but anyone wanting to come to an event sometime can at least ride along... :)
Last few events this year will include Aug 31st and Oct 11th at BeaveRun (Steel Cities region), Elkins Airport (SWVR) on sept 6th and a couple of local events in Oct and Nov...
I am building an E-Stock MR2 at the moment so that'll be the car I'll be tossing around for a lot of the other events... expecting it to be a lot of fun too and much cheaper to operate...
Martin V.
gtfour77
Postby abraxxa » Thu Aug 28, 2008 2:21 pm
I've got the C-One since two years, no problems with it at all.
facelift ST205
abraxxa
Postby darthripley » Wed Sep 10, 2008 11:51 pm
In the MR2 we have a TRD 1.5 way clutch type LSD & we put Kaaz LSD 75W90 fluid in it which works just amazing imho.
The LSD was making some noise at first, there wasn't enough fluid in there & you could hear/feel the clutch plates chatter together on sharp turns.
Once we put in the Kaaz fluid it all the chatter & vibration went away & has been flawlessly smooth ever since.
We purchased the Kaaz fluid from 240sxmotoring.com which shipped promptly without any hassle.
I have a couple of quick questions.
1. I have a 2-way TRD LSD on its way - can I just "plop" it into my ST205 rear pumpkin or will there be a problem with the axle stubs?
2. Can you "plop" a ST205 Torsen LSD into a ST185 open diff pumpkin without having to modify anything?
Thanks in advance! :)
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Postby gtfour77 » Mon Oct 13, 2008 11:44 pm
darthripley wrote:In the MR2 we have a TRD 1.5 way clutch type LSD & we put Kaaz LSD 75W90 fluid in it which works just amazing imho.
I must have missed your reply...sorry...
The 2-way should fit right in without any modifications as long as your backlash and such is correct.
LSD into an open carrier will require LSD stubs... hope this helps.
Martin V.
gtfour77
Postby smog7 » Fri Jan 02, 2009 6:34 pm
how many clutch plates does the cusco unit have?
-omar
rally tarmac 1990 st185
smog7
Postby gtfour77 » Mon Jan 05, 2009 4:29 pm
I am really not sure, there are a few....
Martin V.
gtfour77
