Rear diff options...real LSD's...
Postby lumbercis » Mon Jan 05, 2009 4:52 pm
I think you can see a diagram on Cusco's website.
J.
Caldina powered...
lumbercis
Postby CMS-GT4 » Mon Jan 05, 2009 6:20 pm
On a related note. We should also be able to use the rear LSDs for the Rav4. At least the models with a compatible gearbox. TRD made a rear lsd for the rav 4. I know a torsen was an option, but I am unsure if that was considered the trd dif for the rav4 or a clutch pack was offered as well.
One of these threads around here lists the ratio of the rear dif. If we could verify the ratio of other rear difs that may increase rear lsd options. There was a rumor a while back that the ae86 and is200 rear diffs were the same ratio as the alltrac. I have not seen proof though.
Postby darthripley » Mon Jan 05, 2009 7:52 pm
One thing to note regarding the AE86 rear diff is the TRD clutch type uses the same clutch plates as the ST205 ... the replacement clutch plates/repair kit are the same part numbers.
I kind of wondered if you could fit an AE86 TRD clutch type in a ST205 rear diff, but I haven't done enough reasearch on the gear ratios yet.
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Postby CMS-GT4 » Mon Jan 05, 2009 8:54 pm
If the at.net info is correct then this is the rear dif ratio: 2.928.
I am not sure if toyota makes another rear dif that matches unless maybe the rav4. I am curious if the 185 housing was used that if most other toyota rear difs would work in the housing and rely on the 185s dif ratio.
Re: Rear diff options...real LSD's...
Postby Landon » Thu Mar 10, 2011 6:48 pm
bring this back from the dead.... lol. any more info on the cusco diff? i want to get and lsd and i have an open diff right now. is it a direct drop in if you get the cusco one? the price i found seems a lil steep. lol
White 1995 BMW M3
Black '90 st185 Sold :(
Landon
Postby CMS-GT4 » Thu Mar 10, 2011 6:52 pm
If Martin still has his, I would try and buy it from him if I were you. No rear lsd option for our car is cheap other than buying a second hand torsen.
Postby darthripley » Thu Mar 10, 2011 7:35 pm
^ exactly. martin had that cusco for sale for an absolute steal of a price. i would have picked it up if i didn't already have the trd 2-way clutch type lsd.
and you don't just plop an lsd into the pumpkin. you have to have the backlash set correctly by a shop or someone who knows what they are doing.
Female Moderator
darthripley
All Trac Goddess
Postby CMS-GT4 » Thu Mar 10, 2011 7:49 pm
Yep. If my funds were not going to restore myself I would have upgraded from the torsen to his cusco. I did manage to buy a few of his other goodies though.
Postby Landon » Fri Mar 11, 2011 11:52 am
well fancy the fact i just got the highest score on my manual transmissions class where we just went over backlash and pinion depth. lol. anyways, thanks guys and i'll try an find this martin fella and ask him. Josh, if you ever upgrade look me up if you wanna get rid of your torsen.
White 1995 BMW M3
Landon
Postby TRDTurko » Thu May 19, 2011 4:12 pm
cant wait to get one of the cuscos for my 165! no more open diff :D
So you like the 1 way for autocross?
Anybody else use a 1.5 or 2 way?
88 Celica GTS - RIP
93 Honda Civic - RIP
85 Honda Civic - Sold
08 Mazda 3 - Daily
TRDTurko
