Aluminum vs Poly Diff Mount
Postby Parkins » Fri Jul 03, 2009 3:59 pm
Hey guys, I know there are a million threads on the diff mounts, and I've gone through them all. My question is what are the pros and cons of each? Why choose aluminum over poly or poly over aluminum? They are 2 very different materials and must have rather different results...
Thanks
Parkins
Postby Parkins » Fri Jul 03, 2009 5:49 pm
Well I think more of what I wanna know, is how badly is your car vibrating with the solid mount? Mine is mostly a daily driver and I'm not sure how much vibration I really want...
Parkins
Postby gt4tified » Fri Jul 03, 2009 9:18 pm
Its a rear diff you're speaking of, that's mounted to the sub-frame, not the body. Even so its in the back of the car, so unless you drive from the back seat, I doubt it will be that noticeable.
ST185 JDM GT-FOUR RC- "White Trash"
[url=http://imageshack.us][img]http://img231.imageshack.us/img231/8264/dynographsmallstretchedmu9.jpg[/img][/url]
gt4tified
Images: 5
Postby masco » Tue Jul 07, 2009 3:43 pm
slightly more vibrations with the solid rear diff mount. some people are concerned with the durability of the rear diff, and go with a poly mount. if you go solid you should stiffen up the rest of the mounts at the same time to reduce the stress placed on the rear diff. subframe bushings, poly motor mounts, maybe front subframe bushings, and you should be good. if you do all this im sure you will notice more vibrations.
You should drive from the back seats to improve the weight ratio of your car. :P
1990 Turbo4wd - 1990 Corolla GT-S - 2002 RX300
masco
Re: Aluminum vs Poly Diff Mount
Postby aus jd 2703 » Tue Jan 03, 2012 11:51 pm
It's been awhile so what are people experience of poly vs ally diffmount? Is it dd livable or not really
aus jd 2703
Postby aus jd 2703 » Thu Jan 05, 2012 6:48 am
Anyone?
aus jd 2703
Postby klue » Thu Jan 05, 2012 3:53 pm
I doubt anyone has put on a poly mount, and then switched to alloy, or vice versa.
The difference is obvious, the harness. Polyurethane has some pliability where as alloy is near solid as you want to get. They can both be daily driven, and would problem be alot more comfortable than a damaged mount
Return to Drivetrain Central
