Cheap front LSD's
Re: Cheap front LSD's
Postby Sifu » Fri Jan 29, 2010 9:50 pm
Doubt it will happen... But subscribed...
BROKEN! BUT NOT BEATEN!
2005 Scion tC FW21
1985 AW11
1987 AW11
Sifu
Postby Georonimo » Sat Jan 30, 2010 4:41 pm
Here is the reply I received earlier today:
Hello Jorge,
is this older diff compatible with the newer transmissions? I don't see why we wouldn't be able to make this, but it would most certainly be more expensive than a typical front lsd due to the addition of the extra center gears as well as the shaft(s).
how much are the TRD and TTE ones mentioned in the forum?
Thanks,
Stephen
Based on the link CMS-GT4 posted, I'm assuming the diffs are the same between the generations with the exception of the extra components for the diff lock mechanism or the Viscous coupler. I don't know very much about the TTE/TRD diffs mentioned but I'm under the impression that they were limited production parts made many moons ago and no longer available new. Any more information/input would be appreciated and very helpful in getting this unit into production.
If you guys know of any other parties that may be interested in this or very familiar with the workings of our transmissions please point them in this direction so their voice can be heard.
Thanks again!
Georonimo
Postby Frankencar » Sun Jan 31, 2010 3:48 am
The gearbox that is slowly making its way into my rallycar was built by the guy who used to build them for the factory team when they ran Paris-Dakar. He said with enough effort and money things could be machined and massaged enough to fit an mr2 lsd in place of the open front diff. Since I pretty much ran outta budget, I kept the open diff. I can try to get particulars on whatall needs doing from the guy, if there's interest.
Frankencar
Postby CMS-GT4 » Sun Jan 31, 2010 2:18 pm
Fitting the mr2 lsd as a front dif has been a rumor for a long time. If you could find details we would appreciate it.
Postby Frankencar » Mon Feb 01, 2010 1:50 am
...and may continue to be. I asked Robert what the specifics were on this option and he said vaguely that it would involve machining so much of the case out that he worried about weakening it. I guess we're back to hoping this outfit makes a drop in setup.
Frankencar
Postby Georonimo » Fri Feb 19, 2010 4:58 pm
More correspondence with Stephan at M-Factory
Hi Stephen,
I've been reading up a bit and can't seem to find any info on pricing for the TTE/TRD units. They're obsolete so I guess they go for whatever the seller can get these days if one ever becomes available.
The diff appears to be the same from what I've read and heard with the exception of the extra outer ring. I'm working on getting my hands on a viscous center section and related components from a newer generation transmission to send to you if you are interested in checking them out.
What sort of price range do you think something like this would fall under? assuming both a front and center lsd type diff is made. How many people would you need on board?
Thanks,
Jorge
His reply was:
Hello Jorge,
we would require the minimum 10 units. For price, it's really hard to say, but we should be able to keep it under $1k.
Thanks,
Stephen
That said, I'm currently looking to get my hands on an ST205 diff assembly (assuming this is the best starting point) to send to M-factory for measurements. Once that's in hand we can get the ball rolling. Does anyone have one they wish to loan out for a good cause or sell for a reasonable price?
Georonimo
Postby CMS-GT4 » Fri Feb 19, 2010 5:46 pm
Honestly, you could get any of the diff units for measurements since they are all basically the same and function on the same principal. All open front, viscous coupling center.
Postby Georonimo » Fri Feb 19, 2010 6:39 pm
CMS-GT4 wrote:Honestly, you could get any of the diff units for measurements since they are all basically the same and function on the same principal. All open front, viscous coupling center.
You wouldn't happen to know of any floating around, would you? What would need to be changed to an ST165 unit for it to work in a 185 or 205 trans?
Georonimo
Postby therieldeal » Fri Feb 19, 2010 6:52 pm
good luck with the GB jorge, i can say for sure that mfactory makes some excellent products. i still have one of the prototype diffs kicking around from the group buy i ran, if anyone would like some close up pictures of their work.
i recently converted my escort to an E153 trans from a camry... if only the timing were better i most definitely would have put an MFactory diff in there. they must be a recent addition to their catalog, because they didnt have them available back in october when i purchased my Quaife. unfortunately my timeline was too short to be able to organize another group buy at that time :(
1995 Escort GT
Mazda 323 GTR Engine
2000 Camry V6 E153 transmission
ST185 axles
11.87 @ 117 mph
therieldeal
Postby CMS-GT4 » Fri Feb 19, 2010 7:30 pm
I know sometimes 185 gearboxes are listed here for cheap or free. I would just post a WTB in the FS section and look through some of the threads to see if some are still available.
Postby Georonimo » Sun Mar 14, 2010 2:53 am
Found one! Waiting on a shipping quote. I should have it in hand by weeks end then it's off to M-Factory for measuring and then pricing/group buy requirements.
Just a reminder, all payments and shipment will be handled directly by the manufacturer (M-Factory).
Georonimo
Postby phattyduck » Tue Mar 23, 2010 9:51 pm
Too bad I didn't see this earlier... I have the front/center diff and transfer case assembly from my old FWD converted ST205 box sitting on a shelf in my garage.
PM me if I can be of any help here...
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby Georonimo » Wed Mar 24, 2010 12:40 am
phattyduck wrote:Too bad I didn't see this earlier... I have the front/center diff and transfer case assembly from my old FWD converted ST205 box sitting on a shelf in my garage.
PM on the way!
Georonimo
Postby smog7 » Mon Mar 29, 2010 5:45 am
what kind of drivetrain/lsd's were the st185 rally cars running? acd? torsen locked center(like ours)? torsen front and rear?
-omar
rally tarmac 1990 st185
smog7
Postby etantshi » Mon Apr 05, 2010 6:51 pm
Interesting topic for sure. Subscribed, and interested in a GB.
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
