Straight Cut Dog Engagement*READY TO GO* need another person
Postby alltrac101 » Sun Dec 20, 2009 3:04 pm
Conversation with the 2wd brothers
http://www.mr2oc.com/showthread.php?t=374929
I'm going to proceed with this next year, have a couple of people onboard....its going to be a drag ratio, 1-4 straight cut, 5th helical (with top speed similar to the RC). If you have more than 350awhp it will benefit you
Pat
alltrac101
Straight Cut Dog Engagement *IS READY TO GO* need another pe
Postby alltrac101 » Fri Feb 05, 2010 10:32 pm
Ok guys, after weeks of work John Frana, check him out at http://www.franavehicles.com/, have come up with a Dog engagement gear set for 1-4 with 5th being helical synchroed.
He knows its tough out there, so he's agreed to do the test sets or combo of test sets at a reduced price. He needs to do at least 2 sets & will guarantee it for 1 year. Once the development stage is over they will generally cost 10-20% more my dealer cost for the production runs.
I just need another person, it can even be the 1-2 gear set.
A NEW shaft is needed because 1st is part of the shaft
Prices as follows, includes REM metal process, does not incl. shipping
1-2 dog engagement/straight cut gears (New input shaft) STOCK 3-5 will work on the New Much stronger shaft. $2500
1-4 dog eng./straight cut (new shaft above) with new helical/synch 5th. $4000
New Hardned chromoly Forks (#1 & #2) to work with Stock or Frana Gear set $250 each
Ratios as follows:
@9000rpm FD 4.285 24.72"
ratio mph rpm drop
1st 2.571 50.1
2nd 1.632 78.9 4761
3rd 1.174 109.7 5395
4th .900 143.0 5750
5th .727 177.1 6058
Pat
alltrac101
Re: Straight Cut Dog Engagement*READY TO GO* need another person
Postby RedCelicaTRD » Sun Feb 07, 2010 5:59 am
I wonder if Trevor has enough room on his credit cards :evil:
I suck at the heel-toe so no go for me. Would suck to drive around town.
On a side note, if someone was to buy the 1st-2nd set-up, would they be able to add the 3rd-4th setup later on?
Postby alltrac101 » Sun Feb 07, 2010 8:03 pm
RedCelicaTRD wrote:I wonder if Trevor has enough room on his credit cards :evil:
Yes!, 3, 4 & 5 can be added anytime
you can still use the clutch with a dog set, in fact I would still use the clutch to release the hold on the gear to make the next shift while at wot...the only difference is you have shift with a little more authority, no waiting for the synchros....there are a lot of evo guys running around on the streets with ppg dogs
alltrac101
Postby Meurz » Mon Feb 08, 2010 8:07 pm
I'd be up for it but I've got so much more things on the list.. :(
Turbocelica.nl
Meurz
Postby gt4tified » Tue Feb 09, 2010 1:51 pm
Meurz wrote:I'd be up for it but I've got so much more things on the list.. :(
Me too....like getting to 350awhp! :doh:
gt4tified
Images: 5
Postby Simba » Wed Feb 10, 2010 2:12 am
Interesting, but I'd want different ratios, which I assume wouldn't work for him.
Lots of fast, loud things.
Simba
Postby alltrac101 » Sun Oct 30, 2011 8:29 pm
Here's a link to the set http://www.franavehicles.com/dogTC.html
Pat
alltrac101
Postby sleeper » Thu Nov 03, 2011 11:56 am
How much do these cost ?
sleeper
