TORSEN FRONT & OR CENTER LSD $2500, NEED 5 GUYS
Postby alltrac101 » Wed Feb 10, 2010 12:18 am
Like it says, I can have them made, either front & center can be LSD (torsen Type) or 1 open or LSD, LMK....working drawings in progress.....need 5 people
Pat
alltrac101
Re: TORSEN FRONT & OR CENTER LSD $2500, NEED 5 GUYS
Postby RedCelicaTRD » Thu Feb 11, 2010 3:06 am
So we can get a front and center LSD for $2500 or would it be $5000 for both? This would also allow us to ditch the viscous unit, correct?
Postby alltrac101 » Thu Feb 11, 2010 11:30 am
To clarify, its a completely NEW assembly, minus the ring & speedo gear....1 assembly, either front lsd/open center, or both front/center lsd, we have to pick one or the other or both 5 order minumum each....
alltrac101
Postby BADNEWS » Tue Oct 23, 2012 3:51 pm
What ever happened with this?
865AWHP, 591 torque
BADNEWS
Postby Hotrodhendrix » Tue Oct 23, 2012 4:04 pm
El Nino
Postby l00k0v3rth3r3 » Tue Oct 23, 2012 4:19 pm
:rofl:
Hotrodhendrix wrote:El Nino
Gabe
1990 Maroon Audi 90 Quattro
1998 Toyota 4runner Limited
1991 Mazda Miata 1.8l
1953 Dodge B4B 1/2 Ton Pick up - Currently Lawn Art
l00k0v3rth3r3
Postby underscore » Tue Oct 23, 2012 4:48 pm
I too wonder what happened to this.
Postby athousandleaves » Tue Oct 23, 2012 10:59 pm
I'd see the center LSD exploding after some abuse...
Mechanical center diffs are best for true offroading and rock climbing or for track cars that have a bazillion dollar budget.
The viscous center unit on our cars really isn't that bad.
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby alltrac101 » Thu Nov 08, 2012 11:50 pm
Never got a response from anyone & I didnt want to pay for 5.
I can still get it done tho & at 2500 the price is reasonable
Been thinking of a front/center LSD with some kind of spool to remove the viscous to cut some weight
alltrac101
Postby BADNEWS » Fri Nov 09, 2012 12:20 am
I would be in for a front lsd with a center open cause I am having my VC unit upgraded right now. Are these torsen or clutch type? I know torsen center LSD's break so i would shy away from that. If others wanted a clutch type I would sell my VC unit.
865AWHP, 591 torque
BADNEWS
Postby l0ch0w » Fri Nov 09, 2012 1:01 am
It would be cool if we could get clutch type LSDs for the front and center...
Andrew
1991 Red Alltrac
l0ch0w
Postby alltrac101 » Fri Nov 09, 2012 1:10 am
since the front diff is part of the structure for the assembly everything has to be made, Frana helical assemblies hold up. Here is one for the srt4 http://www.franavehicles.com/diffsminispools.html. The factory torsen cage is much lighter made of a lesser material. There is no room for a clutch type, if i remember correctly the id for the front diff is less the 3"....with a hole 1" od for the axle. I havent thought out the effect of putting a spool instead of a viscous fully yet
alltrac101
Postby BADNEWS » Fri Nov 09, 2012 1:27 am
I know sleeper and Trevor both ran a welded center. Trevor didn't like it so he took it out. Sleeper runs it in his car. I saw this video and decided this is not what I want for my car:
http://www.youtube.com/embed/zQbVYScwaDs
So count me in for a front torsen with a center open that still can use the factory VC unit. I know Quaife UK is looking at making a front diff in another thread but I have little hope it'll go through.
Plus the research I did on quaife making center diffs they state that if you use their diff for drag racing it will break. So that is why I'd like to stay away from the center diff being a torsen.
865AWHP, 591 torque
BADNEWS
Postby BADNEWS » Fri Nov 09, 2012 2:00 am
maybe we could do a center too. I guess quaife just didn't have enough room to make it reliable. But then again I think our trans has less room. I'm guessing on that though.
Effective June 15, 2001, Quaife America will no longer replace broken differential housings on 76.309.155 (9B1) Center Differentials at no charge.
We have found that, due to design constraints of the transmission, the original equipment third gear that meshes with the center diff housing is prone to failure under extreme loading in modified vehicles. When this gear fails, it may cause the gear teeth ground on the Quaife housing to break, necessitating replacement. The Quaife Center Differential made for the Mitsubishi Eclipse/Talon AWD Turbo models are built from very high strength, case hardened material. However, even the superior construction of the Quaife Differential may fail under these situations, under no fault of the Quaife product.
Since this type of failure is not a fault of the Quaife product, we will not replace a broken housing that is due to this type of occurrence free of charge under the Quaife lifetime warranty policy. We will, however, replace the housings at a specially arranged price that covers our manufacturing costs.
All other components of this differential remain fully covered under our limited lifetime warranty.
For more info, contact our tech department at (949) 240-4000.
865AWHP, 591 torque
BADNEWS
