st215 gt-t shifter
st215 gt-t shifter
Postby snakeeater » Sun Oct 03, 2010 9:19 pm
would a st215 shifter bolt in to a st185??? or am i just dreaming? what about the st205 into a 185??
90 gt-four
sold,
jzx100 owner
snakeeater
Re: st215 gt-t shifter
Postby NoMan » Sun Feb 16, 2014 6:25 pm
Bump!
I would also like to know. The st215 have cheap short shifters.
NoMan
Postby phattyduck » Mon Feb 17, 2014 5:34 pm
Pictures?
I have an ST205 shift lever in my Camry - if that helps. Most of the cable-shifter Toyotas are compatible, at least from the late '80s through '90s.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby NoMan » Mon Feb 17, 2014 5:50 pm
Heres a picture. I dont know if even a st205 shift lever fits in the st185. But if all 3 are the same then that would be wonderful!
NoMan
Postby phattyduck » Mon Feb 17, 2014 6:01 pm
NoMan wrote:Heres a picture. I dont know if even a st205 shift lever fits in the st185. But if all 3 are the same then that would be wonderful!
Yeah, that will fit. Its hard to say whether it will put the shift lever in the right place or have shorter/longer throws than the stock shifter... but it will fit.
phattyduck
Postby killemalltrac » Mon Feb 17, 2014 6:55 pm
interesting.. I happen to have an st205 shifter sitting in my garage ;)
#80sMurderCar
killemalltrac
Images: 10
Postby NoMan » Mon Feb 17, 2014 7:51 pm
Ah they just had to make it hard for us.. Would be great if it could be used as a upgrade to the st185.
I would try it but i dont have the money for this :( (cracked exhaust manifold and broken o2..)
NoMan
Postby CMS-GT4 » Mon Feb 17, 2014 7:54 pm
The 7th gens are cheap, and i read those fit. You just need spacers for the housing, which you can find at Napa or sears.
