Sequential 6-speed and rear diff
Postby CMS-GT4 » Sat Feb 26, 2011 9:25 pm
You can read the pdf if you like. Its listed for Lancer, gt4 and Lancia. I am sure an engine plate is needed for each one unless they provide a housing for each model.
only 22,000 pounds.
http://www.maktrak.com/products.htm
I imagine for the cost, you could go to a later evo gearbox instead.
Re: Sequential 6-speed and rear diff
Postby Mafix » Thu Mar 03, 2011 5:48 pm
for that money you can buy the getrag internals for the wrc celica. that's only 15K pounds. includes transfer case and e15X bell housing.
Postby DeeCee » Sat Mar 05, 2011 6:06 pm
may as well buy a car with better kit than a celica tbh
DeeCee
Postby Flying Bajan » Thu Mar 10, 2011 5:27 pm
There was no such thing as a WRC Celica. There was however a Group A Celica that ran in the World Rally Championship. They uses Xtrac gearboxes, not Getrag. As did the WRC Corolla which also used to the 3S-GTE.
I have personally driven 2 ex-works Group A GTfours (ST185 and ST205) and been driven in an ex-works WRC Corolla and they were all Xtrac equipped.
Flying Bajan
Postby built2run » Sat Apr 02, 2011 4:14 am
mmmm xtrac
ST165, black: parted and gone
ST165, white: sold to friend
built2run
Postby rallygarage » Fri Sep 23, 2011 10:19 pm
We have this transmission in an Evo at our shop here in US. It is amassing. This is an open class rally car. I have a 6 speed dog box on my Gt4 and would like a sequential but its $25k. There is also a 5 speed dogre option from Sweden
rallygarage
Postby lumbercis » Sat Sep 24, 2011 3:40 am
Any links to company that makes that 5-speed dog box? Oh, also, where did you get your 6-speed box from?
Caldina powered...
lumbercis
Postby rallygarage » Sun Sep 25, 2011 6:22 pm
My 6spd dog was made by Stafs Silent Gear in UK. they are now Elite or something else. It was designed and sold by Darel Staniforth in UK. Front and center diffs are TRD LSD's. There is a custom cast case extention that houses 6th gear. It protrudes into the left wheel well. Had to modify frame rail. It has homologated GrA gravel ratios. Everything is straight cut even final drive and oil pump gear.
5spd is still produced and should be available from Sellholm Tuning in Koping Sweden. I dont know what he does for Diffs. This kit was sold by TTE when they were in rally business along with Xtrac.
There are used XTracs out there but you will need Hybrid axles and TTE rear subframe an difff. Spares take forever to get.
Stock transmission even from RC handicaps the car bad.
rallygarage
Postby CMS-GT4 » Sun Sep 25, 2011 7:32 pm
If only they still offerred the trd front diff. Good info about the 6speed.
Postby Flying Bajan » Mon Sep 26, 2011 10:07 am
I'd avoid the Staff's stuff if I were you... there was a clubmanspec GroupA GT4 here in Barbados a few years back that had one and it was perpetually breaking.
I do hear good things about Sellhom though.
Flying Bajan
Postby Meurz » Mon Sep 26, 2011 4:59 pm
Fensport has had PPG (Oz) develop a 5 speed kit for the OEM box as well; http://www.fensport.co.uk/Parts/Model_19/Category_3/2463.
Turbocelica.nl
Meurz
Postby Flying Bajan » Mon Sep 26, 2011 6:17 pm
It's no longer listed on PPG's website.... sent them a message to enquire. Will report back if they respond positively.
Flying Bajan
Postby Flying Bajan » Tue Sep 27, 2011 10:54 am
Well PPG seem to be on the ball.... here is the response I got less than 24 hours after sending the request.
Hi Martin,
This gearset was only ever designed and manufactured as a straight cut dog engagement set.
Current ratios in stock are: 3.000 / 1.933 / 1.350 / 1.000 / 0.786.
Final drive ratio in stock is 4.1.
The gearset retail price is $11,995 AUD
Freight to Barbados is $370 AUD
Regards
Mark
Sales Department
Flying Bajan
Postby Flying Bajan » Tue Sep 27, 2011 10:55 am
As to why the kit is in the region of double the price of one for an Evo is beyond me however..... :-(
Flying Bajan
Postby rallygarage » Tue Sep 27, 2011 1:34 pm
Here is the deal with Staffs. First of all you cant get one unless I sell you my gearbox as they are no longer made and Staffs is out of business. The reason Staffs was created is to provide homologated ratios so that you could run FIA GrA. That is not needed any more. The problem with it was that it used a helical final drive that applied axial pressure on the case. that was corrected by fabricating straight cut final drive. I ordered my from Gemini. If you look at PPG Kit it also has straight cut final drive. That is one of reasons the cost is higher.
Sellholm sold more of these than all the others put together including XTrac. He has the greatest ratio selection. His parts are in stock so you can get them fast for repair..
rallygarage
