Swap to 4wd?
Swap to 4wd?
Postby Fearlessmortal » Wed Apr 06, 2011 7:19 pm
I've been searching for a project St165 shell. Alltracs are of course hard to find but non alltracs are not. I tried searching but I have not found a satisfying answer anywhere. Can a non alltrac be swapped to a alltrac drive train? Also is it a bolt in swap? Thanks in advance.
Link is one of the cars I've come across.
http://baltimore.craigslist.org/cto/2262221222.html
Fearlessmortal
Re: Swap to 4wd?
Postby CMS-GT4 » Wed Apr 06, 2011 7:29 pm
Fact1: Yes it can be done.
Fact2: It is not simple or straight forward.
Fact3: Its cheaper to buy a decent alltrac and fix it up.
Fact4: You often have to travel to find a decent alltrac.
Re: Swap to 4wd?
Postby 88gt4DE » Wed Apr 06, 2011 8:02 pm
+ 2 ^^^^ be patient and look in the south ... simply for less rust ...
Re: Swap to 4wd?
Postby MrDB » Wed Sep 28, 2011 10:48 am
Whole rear end of a fwd celica is different to the rear of an alltrac...
No mounting points apart from probably top mounts.
Floor pan is higher in alltrac for fuel tank.
fwd fuel tank is infront of rear axel and alltrac is behind
TBH to much work......
MrDB
Re: Swap to 4wd?
Postby Hotrodhendrix » Wed Oct 12, 2011 2:10 pm
Only time this may be worth it if you really want a st205 but dont want to do something illegal in doing it. :evil:
Re: Swap to 4wd?
Postby concealer404 » Wed Oct 12, 2011 9:27 pm
I remember reading there were a few weird ST184s that were easier to convert than normal.... Don't really remember the specifics, though. Gave up on that idea a long time ago.
Cars and stuff.
concealer404
Re: Swap to 4wd?
Postby New Guy » Wed Nov 09, 2011 9:43 pm
I recall reading that the hatchback and the All-Trac are similar, you just need to raise the floor pan of the trunk... Or some such like that. Damned if I can remember where I read it, though, and that might apply to the ST204/205, not the ST18x...
Proud owner of an ESV220x.
New Guy
