shift link part #
shift link part #
Postby Landon » Wed Jun 01, 2011 4:46 pm
hey guys, so the linkage on my tranny is pretty worn and i'm trying to figure out the part #... the two shift cables attatch to the two levers on the tranny, one flat, one vertical. the lever that is flat then links to the vertical through an arm. at the end of this arm there is kinda a square bushing. that bushing is shot. i can't find the part in my sources so far. any ideas? if it makes any sense what i am talking about.... lol
White 1995 BMW M3
Black '90 st185 Sold :(
Landon
Re: shift link part #
Postby Landon » Wed Jun 01, 2011 7:33 pm
found it! 90389‑10009 toyodiy is amazing. this could be a important part with improving shift feel if it hasn't been discovered already.
White 1995 BMW M3
Landon
Postby jonnyboygt4 » Wed Jun 01, 2011 10:56 pm
are you referring to the sugar cube in the linkage? also did you replace the shifter bushings with oem bushings or brass?
91 JDM ST185
"just a little 4-banger"
jonnyboygt4
Postby Landon » Thu Jun 02, 2011 2:41 am
yes i'm talking about the sugar cube. lol. it is now almost a triangle it's worn so bad. shift linkage has new brass bushings.
White 1995 BMW M3
Landon
