How do I replace Viscous Coupler
Postby cmonteiro1 » Thu Jun 23, 2011 12:15 am
Ive brought my car in several times to get tuned. Each time it has gone in, the 4wd dyno pack has issues and will not function so the tuner has to tune in FWD. Today I picked up the car and he mentioned that he believes that the Viscous Coupler is bad and needs to be replaced. With that said, a few questions
1) Anyway I can test and confirm that this is in fact the problem
2) If it is the problem, how do I replace it? Is it a difficult job? Any write ups on it.
3) Any other thoughts on what it could be if not that ?
Thank you in advance for you rhelp
1991 ST185
Mods:
Aussie DP, 3in Exhaust, Wideband A/F, BayArea FMIC, HKS SSQ Blow Off Valve, Forge Waste Gate Actuator, AEM ECU, SARD 800 , Walbro Pump, ATS Fuel Rail Mod, ATS Fuel Pres. Reg. Mod., 60 trim upgraded ct26.
cmonteiro1
Re: How do I replace Viscous Coupler
Postby DudeMan » Thu Jun 23, 2011 3:53 am
1) I would imagine a dyno could show how much torque is being distributed between the front and rear wheels. Should be a 50/50 split. Anything less and the VC is probably worn.
2) Its the fluid that goes bad and needs to be replaced. Unfortunately our VC's are sealed from the factory.
I believe there was a company in Europe that was offering to drain the fluid, replace it and tap a drain plug so it could continue to be changed without hassle.
Your best bet may be to talk to some transmission shops and see if they're willing to try. Otherwise you can simply weld it, not that great for a daily ride though, your wheels will chirp on sharp turns.
3) Only other advice I can offer is trying a different dyno/tuner.
Do you know how much mileage the tranny has?
It would probably be much easier to just find one with less mileage.
-Chase
1990 4Runner SR5
1990 Celica GT-Four
DudeMan
