25mm spacer
25mm spacer
Postby binangret » Sun Jul 10, 2011 6:27 am
Hi,
I have an 88 alltrac and want to add 25mm spacers on the rear. Do spacers affect the drivetrain since the front the rear track are not proportional anymore? The rears will be wider so im guessing it would affect the drivetrain components..
thanks
binangret
Re: 25mm spacer
Postby celicat93 » Sun Jul 10, 2011 6:32 am
Yes. Because the circumference of your turn will be larger, the rear wheel on the outside of your turn will rotate faster with the spacers than they did without them because they are covering more ground than they did before.
celicat93
Re: 25mm spacer
Postby binangret » Sun Jul 10, 2011 1:52 pm
celicat93 wrote:Yes. Because the circumference of your turn will be larger, the rear wheel on the outside of your turn will rotate faster with the spacers than they did without them because they are covering more ground than they did before.
Thanks, will it have negative affects though? Thats my real question
binangret
Re: 25mm spacer
Postby jonnyboygt4 » Sun Jul 10, 2011 7:22 pm
i ran wheel spacers without any sort of handling issues....was running 33mm spacers...ran it like that for 2 years
91 JDM ST185
"just a little 4-banger"
jonnyboygt4
