Wierd knocking from rear left
Postby woot woot » Thu Jul 21, 2011 5:46 am
Hey not to sure what the issue is but when moving form a standstill i hear a knocking noise like its revolving with the wheel but it stops when i get up to higher speed.
I had an issue when changing the wheels about a month ago with the rear of the car not being able to move back or forwards so i gave it some gas and heard a massive bang not sure if its related or somethig else.
Any help appreciated
Sorry its so vague
woot woot
Re: Wierd knocking from rear left
Postby phattyduck » Thu Jul 21, 2011 3:41 pm
This is probably more of a 'suspension and brakes' issue. Pull that wheel off and check the brakes - mainly the parking brake that is located *inside* the rear brake disk/drum combo. You probably have a broken part in there.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby woot woot » Sat Jul 23, 2011 12:38 pm
It gets worse also when i go into reverse. but i already changed my diff mount. still not sure
woot woot
