st165 flywheel!!!!
st165 flywheel!!!!
Postby zgookgumby » Wed Aug 17, 2011 6:04 pm
Is the st165 flywheel the same as the st185???
zgookgumby
Re: st165 flywheel!!!!
Postby alltracst185 » Wed Aug 17, 2011 7:52 pm
I'm sure it is...If you need one I have one. PM me :wink:
alltracst185
Postby sharpie_101 » Wed Aug 17, 2011 8:21 pm
No, it is not. The bolt pattern is different.
J
sharpie_101
Postby klue » Wed Aug 17, 2011 10:08 pm
sharpie_101 wrote:No, it is not. The bolt pattern is different.
J
x2
Postby zgookgumby » Wed Aug 17, 2011 10:13 pm
Any idea what other flywheel will fit the st165?
zgookgumby
Postby klue » Thu Aug 18, 2011 12:35 am
Aftermarket
Postby 91 alltrac » Thu Aug 18, 2011 4:56 am
if you look at the aftermarket,they oblong several holes I believe to make it fit both cars, you could have a machinist do the same on an oem 185 flywheel.
92 alltrac
91 alltrac
88 alltrac
91 alltrac
