How many Qts are used in a st205 transmision?
Postby alltracst185 » Thu Sep 22, 2011 7:44 pm
I have a ST205 tranny swap in my st185 and need to know the gearbox capacity and or anything else that needs to be known when refilling for use. What is the best gear fluid? Also would like to know about diff fluid for my 90 All-trac.
Thanks!
alltracst185
Re: How many Qts are used in a st205 transmision?
Postby Gary ST165 » Fri Sep 23, 2011 8:23 am
ST205 E154F transmission
ST185 rear "open" differential fluid capacity
ST205 TorSen LSD rear differential
ST165 turbo 4WD
Gary ST165
Postby alltracst185 » Fri Sep 23, 2011 8:00 pm
THANKS GARY!!! :D
alltracst185
