Can someone set me up with a new flywheel/clutch kit.
Postby nightcrawler52 » Fri Sep 23, 2011 10:23 pm
I have a 91 Celica alltrac. I've been to 2 different shops trying to fix my clutch. When I bought the car the clutch was burned up in it badly. The first shop replaced the clutch and turned the flywheel. It still slips. Second shop had the flywheel miked, and returned and installed a new clutch. It still slips. So now I just said F it, im going to replace the flywheel/pressure plate, clutch disk, throwout bearing with aftermarket that someone has on here that I know will work. Because as my mechanic and I discussed this situation, we are thinking that the parts they were getting were not compatable with the alltrac. So I want to replace it with all aftermarket that I will know will work.
nightcrawler52
Re: Can someone set me up with a new flywheel/clutch kit.
Postby klue » Sat Sep 24, 2011 2:22 pm
Hi, what clutch kit are you using now?
Anytime you reuse a flywheel is must be machined, this is also good practice for the pressure plate.
