1st gen 3sgte transmission options
Postby bigbacon » Fri Sep 23, 2011 10:42 pm
What other transmission can mate up, without mods, to a 1st gen 3sgte?
bigbacon
Re: 1st gen 3sgte transmission options
Postby NewGuy » Thu Aug 23, 2012 3:39 am
SOMEONE HALP US
NewGuy
Postby Spectra1 » Thu Aug 23, 2012 4:50 am
SOMEONE HALP US
Im assuming the st185 (E150F) and st205 (E154F) transmission would mount up just fine but I have no actual experience with this so im sure someone will chime in here. The only issue I can think of might be the speedo cable.
Im sure this has been discussed many times, you could probably do a quick search and find your answer.
93 St185 DD
90 ST185 - Project
Spectra1
Postby Awesome-Trac » Thu Aug 23, 2012 4:52 am
I've done a 2nd Gen tranny swap with a 1st Gen engine and works perfectly. From what I've learned from this site and all the other awesome owners is you can swap a 1st,2nd and 3rd Gen tranny with eachother.
Differences: 3rd Gen tranny has a electronic speedo unlike the 1st and 2nd which use cable
Hope this helps
•Daniel
Awesome-Trac
Postby NewGuy » Fri Aug 24, 2012 4:47 am
i used search and lurked forever on the subject... so i cant take a 3sge tranny and use that transferring my diff onto it?
only gt4 trannies will work???
NewGuy
Postby Awesome-Trac » Fri Aug 24, 2012 6:17 am
3sge tranny? if im correct those only came in FWD versions with no driveshaft and rear diff so i dont if that would work at all unless you plan on removing your car from being AWD to FWD? ...you can bolt the the FWD 3sge tranny on a 3sgte engine and they will work cause there are a few people here who have done this type of project unless im getting what your planning to do wrong....please feel free to correct me
•Daniel
Awesome-Trac
Postby fussellbug » Fri Aug 24, 2012 8:25 pm
To replace the stock all wheel drive transmission you will need an 'E' series transmission and differential. I have heard of people removing the differential to make a FWD transmission but don't know of anyone who's added an all wheel drive differential to a FWD transmission. The 3S-GE used the 'S' and 'C' series transmissions which were never meant to be adapted to all wheel drive and aren't as strong as the 'E' series.
There is however a FWD 'E' series transmission in the V6 Camry that could potentially be combined with the all wheel drive differential but I've never heard of it being done. I for one would just look for another All-Trac transmission and save myself the extra work.
fussellbug
Images: 36
Postby NewGuy » Sun Aug 26, 2012 4:06 am
ok thanks for the help..
NewGuy
