Tell me your dream wish list.....
Postby Flying Bajan » Sat Sep 24, 2011 2:52 pm
In terms of release bearing, clutch, pressure plate and flywheel for an ST185 running an E154F gearbox from the ST205WRC given the below....
Street driven (sometimes VERY spirited on twisty tarmac roads).
No drag racing, but occasional hard launches.
Desire no or very little clutch rattle.
Desire reasonable (near stock) clutch pedal pressure.
Forged stroker on GT30 turbo with water injection, 264 cams and autronic.
Pump fuel mainly, but with occasional use with VP 109 fuel and suitable map.
Desire quality parts that will last - as we all know, changing a clutch on an ST185 is a bitch of a job :-)
Let's hear your comments and feedback gents !
Flying Bajan
Re: Tell me your dream wish list.....
Postby Flying Bajan » Wed Sep 28, 2011 7:30 pm
No one with any input then ???
Flying Bajan
Postby alltracst185 » Wed Sep 28, 2011 9:18 pm
OS Giken twin plate with internal hydrolic slave :wink:
alltracst185
Postby Flying Bajan » Fri Sep 30, 2011 1:01 am
Ok, so that's one opinion on clutches... anyone got any strong feelings about flywheels ???
If you care to, please PM me a good source for the OS Giken clutches.
Flying Bajan
Postby snakeeater » Fri Oct 07, 2011 9:38 pm
If you dont care about $ Ive heard JUN flywheels are top notch, forged
90 gt-four
sold,
jzx100 owner
snakeeater
Postby Celi-GT4 » Wed Oct 12, 2011 1:53 am
os comes with a flywheel i belive. It rattles a bit though
12.4 @ 115mph Topeka Kansas NA2005
12.2 @ 109mph blew HG Moroso 1/08
Sold out, now on stock 3rd gen
Blitz ecu, dp,exhaust, tien ss, carbon driveshaft,light wheels/brakes,os giken twin plate
Celi-GT4
Postby Flying Bajan » Wed Oct 12, 2011 1:59 am
No rattles permitted fellas, so OS twin plate is out.... Opinions ???
Flying Bajan
Postby Hotrodhendrix » Wed Oct 12, 2011 2:12 pm
Flying Bajan wrote:No rattles permitted fellas, so OS twin plate is out.... Opinions ???
Yah the rattles get annoying.. Non car guys look at you like a rattling honda civic. :P
Postby Flying Bajan » Wed Oct 12, 2011 9:56 pm
So what clutch do I use that meets all the criteria in the original post ?
Flying Bajan
Postby Hotrodhendrix » Wed Oct 12, 2011 10:48 pm
Flying Bajan wrote:So what clutch do I use that meets all the criteria in the original post ?
Had a OS GIKEN twin plate but did not like the chatter at all. Once the throw out bearing gave me issues I went with a Comp 6 puck "strip" clutch. Peddle isn't to harsh. engagement is very streetable. Best part is NO chattter. :D
Postby ALLensTRAC » Sat Oct 29, 2011 10:51 am
I think the only clutch that meets your criteria is the Tilton carbon or maybe the carbonetics but there again they are multi-plate and may still rattle. I think abraxxa on here has the carbonetics in his 205. You could ask him. Also Pat has the Tilton. Best part about the Tilton is rebuilds are cheap!
Allen
ALLensTRAC
Postby Hic » Thu Nov 24, 2011 7:02 am
If you want silent 2 disc clutch, with soft as stock feel and usage, buy Helix 200mm twin clutch.
No match, nor Tilton or Carbonetic.
I use carbonetic 2 plate, it is noisy.
Helix is silent, will transfer 600-700Nm easily, cheap to rebuild.
Hic
