MR2 clutch compatible with Alltrac?
Postby Spectra1 » Wed Oct 05, 2011 1:00 am
I have a SPEC stage 3 clutch for a 1990 MR2 turbo and now I need a clutch for an 1990 alltrac. Can anyone confirm if the MR2 clutch will fit the alltrac. Thanks
93 St185 DD
90 ST185 - Project
Spectra1
Re: MR2 clutch compatible with Alltrac?
Postby snakeeater » Fri Oct 07, 2011 3:38 am
yeh im pretty sure :? ... 3sgtes have same cluch i believe. Do a search you should be able to confirm.
90 gt-four
sold,
jzx100 owner
snakeeater
Postby Hotrodhendrix » Wed Oct 12, 2011 2:08 pm
Yep fits just fine. Just make sure not to use the input bearing or what ever its called. :twisted:
