Front LSD !!!!!!!!!!!!!!!!!!
Re: Front LSD !!!!!!!!!!!!!!!!!!
Postby athousandleaves » Sat Apr 27, 2013 8:30 am
:offtopic: :offtopic: :offtopic: :offtopic:
Allen!
What's going on!? We haven't heard anything since last year, is this officially dead?
athousandleaves wrote:
ALLensTRAC wrote:Well I sent Scott an email yesterday and I got an automated response that he will be out of the office until December 3. I will email him on the 4th to get an update. Sorry guys
Really hate to ask but is there any update on this?
Once again, what is the status with Qualife and the front LSD for our transmissions?
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby ALLensTRAC » Sat Apr 27, 2013 11:33 am
I am basically getting no response from Scott. I have sent him email after email. I was waiting until I got a proper response but I haven't. My buddy with the Motovicity account is trying to get an answer but everytime he calls Scott isn't there. I will continue to email bomb him but its not looking good. Once I hear a definitive "no" I am going to start working on Kaaz to see if they would be interested. I still want a front diff no matter what happens. I am sorry to everyone about my 4-5 month hiatus but I had a tough end of year last year (lost my brother suddendly). I have not given up and will continue to search for answers.
Allen
Allen
ALLensTRAC
Postby Tecker185 » Sat Apr 27, 2013 11:47 am
well if kaaz thinks they can make us one i could get another front diff if need be.
89 ST165
89 SV25
86 AW11 2zzge swapped
86 AE86 1uz swap
89 AE95 sedan
89 AW11 Supercharged
17 4runner TRD Off Road
Tecker185
Postby BADNEWS » Sat Apr 27, 2013 12:23 pm
There is not enough room for a clutch type is my guess. The front diff has enough from for the sun and planetary gears only. Not so much to shove at least 3 friction discs and and a cone spring additionally on each side. I would be in complete shock is any clutch style LSD company said they could make it. I think the only way is a helical or gear type.
865AWHP, 591 torque
BADNEWS
Postby ALLensTRAC » Sat Apr 27, 2013 3:49 pm
BADNEW5 wrote:There is not enough room for a clutch type is my guess. The front diff has enough from for the sun and planetary gears only. Not so much to shove at least 3 friction discs and and a cone spring additionally on each side. I would be in complete shock is any clutch style LSD company said they could make it. I think the only way is a helical or gear type.
I had mentioned Kaaz because I remember seeing your thread regarding the TRD front/center combo showing plates that looked like Kaaz plates. That is why I was going to contact them if I don't hear from Scott soon.
Honestly I am thinking of joining in on the Frana idea even though its expensive. If Pat and you both trust his products then my 400whp car should be just fine.
Tecker184 wrote:well if kaaz thinks they can make us one i could get another front diff if need be.
Hey I will make sure that sample diff gets sent back no matter what. They told me it would be sent back so I am holding them to that. Although if Kaaz gets on board we may need the front/center combo with shafts instead of just the front.
Allen
ALLensTRAC
Postby darthripley » Sat Apr 27, 2013 4:24 pm
TRD made a clutch type diff for the front & TTE made them as well so it can be done, the cost is the only real drawback around $5k.
87 AW11 MR2 "Super 2" 4AGZE
99 SXV20 Camry "Maul" 5SFE
Female Moderator
darthripley
All Trac Goddess
Postby BADNEWS » Sat Apr 27, 2013 4:30 pm
The TRD was a combo front and center. They put one of the diffs in the VC location. Wasn't enough room for them to make a front by itself. They had to redesign everything.
I know nothing of the TTE front LSD. Any photos?
I just emailed TTE or as they are now called TMG (TOYOTA MOTORSPORT GmbH) about if they make a front diff and what it would take to get.
865AWHP, 591 torque
BADNEWS
Postby darthripley » Sat Apr 27, 2013 4:49 pm
Female Moderator
darthripley
All Trac Goddess
Postby BADNEWS » Sat Apr 27, 2013 5:16 pm
Whoa!! That is far from being able to bolt into our transmission. They have their own bell housing plate so you can bolt on their specific transfer case. That is more far away than the TRD set. The TRD stuff at least uses the Toyota trans housings.
To me it looks like that runs the front diff where both the stock front and center diff is. Then where the VC unit is they run their own housings and have a hydraulic type center lsd. Looks to be big $$$ for the whole set. Differently is a clutch type front and rear diff though. I maybe wrong but that is what I am seeing from all those parts. Basically you get the whole system with their center diff setup and housings or nothing. I don't see a stock type front diff replacement.
865AWHP, 591 torque
BADNEWS
Postby BADNEWS » Sat Apr 27, 2013 5:28 pm
Just looked at it more. The ring gear is straight cut teeth on it. Which means you also have to upgrade to their dogbox gear set to run it on top of everything else.
865AWHP, 591 torque
BADNEWS
Postby 4rsnduction » Sat Apr 27, 2013 11:26 pm
Has anyone contacted Neil bates yet ?
4rsnduction
Postby athousandleaves » Mon Apr 29, 2013 5:23 am
Allen thanks for the update and keeping on top of Scott for this.
Sorry to hear about your brother, totally understand why we didn't hear from you for a while.
Hopefully we hear something from someone soon before too much interest is lost in this!
1992 White turbo4WD
athousandleaves
Postby alltracman78 » Mon Apr 29, 2013 12:03 pm
I don't know if interest in this will ever be lost. I'm always interested. Price may keep me out because I can't swing 5G right now, but hopefully after I sell my grandfarthers house next year I'll have some more cash to throw at it.
However, I'm pretty sure I'd prefer a helical diff, especially now that I've got a car with a clutch type rear diff [Cressida]. I def prefer the TORSEN in the trac to the clutches.
Postby Domspun » Mon Apr 29, 2013 5:30 pm
alltracman78 wrote:However, I'm pretty sure I'd prefer a helical diff, especially now that I've got a car with a clutch type rear diff [Cressida]. I def prefer the TORSEN in the trac to the clutches.
x2!
Domspun
Postby ALLensTRAC » Mon Apr 29, 2013 8:05 pm
Hey guys I went over to my buddies shop today and I got him harrassing Motovicity so I should be recieving an answer soon. I will write another email tonight and see what happens.
Allen
ALLensTRAC
