Phoenix Power 4.5 / 4.6 final drive......
Postby Flying Bajan » Fri Oct 07, 2011 1:50 pm
Can anyone confirm or deny that these will work in a GT4 / alltrac gearbox ? Originally designed for the SW20 Mr2 of course.
Cheers,
Martin.
Flying Bajan
Re: Phoenix Power 4.5 / 4.6 final drive......
Postby phattyduck » Fri Oct 07, 2011 7:22 pm
I re-used an ST205 final drive on an MR2 2WD differential when I rebuilt it for FWD use. It should work just fine.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby Flying Bajan » Sat Oct 08, 2011 2:51 am
Splendid ! Cheers for that.... Now to find a rarer than rocking horse shite PP final drive :-)
Flying Bajan
Postby phattyduck » Mon Oct 10, 2011 5:03 pm
Flying Bajan wrote:Splendid ! Cheers for that.... Now to find a rarer than rocking horse shite PP final drive :-)
Its funny, because I have long been interested in the 3.6 final drive out of the '92-'94 Camry V6 E153... I spend so much time cruising on the freeway that lower rev's sounds good. :D
phattyduck
Postby CMS-GT4 » Mon Oct 10, 2011 5:31 pm
the 4.2x final drive is the same for both the gtfour and mr2. Here is a bit on it.
http://gtfour.supras.org.nz/428ratio.htm
Postby Flying Bajan » Wed Oct 12, 2011 10:00 pm
Anyone got a source for a PP final drive then ??? I'm on a quest for some seriously short gearing here :-)
Flying Bajan
Postby bozo-merlin » Thu Oct 13, 2011 8:54 pm
what "seriously short gearing" is ?
4.6FD is not shorter than 4th (-2mph) and 5th (+7mph) from V6 camry on 4.285, but you get the shortest 1st and 2nd which is not a good choice.
The longer 1st as you can, the shorter 5th, and good 2-3-4 arrangment is the key
Jérémy
ex 91 RHD ST185 - 2.94kg/BHP
93 RHD ST185 - 2.71kg/BHP
98 RHD SW20 NA
bozo-merlin
Postby Flying Bajan » Fri Oct 14, 2011 1:03 am
That is why I will be using a C-One close ratio gearkit in conjunction with the PP final drive in stead of the stock 4.2ish FD from the GT4 :wink:
Flying Bajan
Postby CMS-GT4 » Fri Oct 14, 2011 5:09 pm
This is the person who was selling the final drives on mr2 oc: MCS Motorsports
Postby Flying Bajan » Fri Oct 14, 2011 6:19 pm
Been warned to avoid that one.
Flying Bajan
Postby CMS-GT4 » Fri Oct 14, 2011 7:07 pm
Any details? That who I was going to buy it from. I don't want to get burned if I ever do.
Postby lumbercis » Fri Oct 14, 2011 7:20 pm
tons of details. Check the feedback forum on mr2oc.
Caldina powered...
lumbercis
Postby CMS-GT4 » Fri Oct 14, 2011 7:31 pm
holy crap, stay away from them. One person mentioned in another thread they are going to get a fd done by the same people doing the lsds. Worth looking into.
