Rav4 Rear Differential Compatibility
Postby MonkeyWrench » Thu Oct 20, 2011 5:26 pm
Has anyone installed either a Rav4 rear differential assembly w/housing in their AT or a Rav4 differential unit in an AT rear differetial housing?
I'm looking to do the opposite. All Trac helical rear differential (w stub axles) in a 97 Rav4 differential housing in a 97 Rav4. I have researched the part #s and they don't interchange but they're off by quite a few model years so that doesn't necessarily mean anything. I don't want to buy and ship the all trac diff if it won't fit.
To be clear, I won't be changing the gears. Just the differential unit.
Matt @ Monkeywrench
1997 Rav4 +Caldina 3SGTE 18psi
2001 Celica GTS 2ZZ-GE 823whp
http://www.monkeywrenchracing.com
MonkeyWrench
Re: Rav4 Rear Differential Compatibility
Postby CMS-GT4 » Thu Oct 20, 2011 5:53 pm
From what I read trd made a rear lsd for the rav4. I remember the part numbers being the same as the gtfour. I would look into those part numbers as your guide.
Postby MonkeyWrench » Thu Oct 20, 2011 6:47 pm
CMS-GT4 wrote:From what I read trd made a rear lsd for the rav4. I remember the part numbers being the same as the gtfour. I would look into those part numbers as your guide.
Great tip. Discontinued but they both come up as 41301-ST000.
My inside rear tire thanks you.
Matt @ Monkeywrench
MonkeyWrench
Postby CMS-GT4 » Thu Oct 20, 2011 8:38 pm
No problem. Good luck.
Postby MonkeyWrench » Mon Nov 07, 2011 5:05 pm
The new rear diff (LSD from ST205) is installed in the Rav4 diff housing, no problem.
The stubs that came with the ST205 diff fit in the diff and work with the Rav4 diff housing but do not mate up to the Rav4 rear axles. Bolt pattern and centering protrusion are slightly larger on the ST205 parts. Any ideas? I could order Rav4 LSD stubs and know for sure they'd bolt to my axles but I don't know if they'd work with this differential. I have a feeling they would, but I need the car up and running for an event this Saturday.
Matt @ Monkeywrench
MonkeyWrench
Postby CMS-GT4 » Mon Nov 07, 2011 5:51 pm
At this point I would likely look for some rear 185 axles. Check the forums like rav4world that have done gtfour swaps. I know that the splines of the front spindles are the same for the celica and rav4. I am swapping rav4 spindles from a rav4 to my 185 to get 5x114 bolt pattern. I am unsure about the rears.
If all else fails, you might be able to machine an adapter to go between the two.
Postby MonkeyWrench » Mon Nov 07, 2011 7:15 pm
Very few others have done the engine swap and none that I can find have done the rear LSD swap. I tried getting a stock LSD from a Rav4 but they're impossible to find. The VIN lookup with the junkyards does not work and they always end up being non-LSD.
I'm going to try the Rav4 stubs. Alltrac axles may work but I don't know if length and outer spline would be right. That'll be plan B.
Matt @ Monkeywrench
MonkeyWrench
Postby CMS-GT4 » Mon Nov 07, 2011 7:19 pm
Hybrid axles maybe? Rav4 St185 inners and rav4 outer.
Postby MonkeyWrench » Thu Nov 10, 2011 4:22 pm
For the record:
96-04 Rav4 and AllTrac differentials are 100% interchangeable
Rav4 output shafts have a smaller 4-bolt pattern than the AllTrac but the rest of the output shaft (splines, seal area) is the same. Spline diameter and length is different for LSD vs non-LSD.
Bottom line: I installed an ST205 helical differential to the stock non-LSD differential carrier in my 97 Rav4. Reused the same ring gear. Did not require reshim. I did have to buy 97 Rav4 LSD output shafts (~$145/ea) because the ST205 LSD output shafts would not bolt to the flanges of my 97 Rav4 rear halfshafts.
Matt @ Monkeywrench
MonkeyWrench
Postby lumbercis » Thu Nov 10, 2011 5:11 pm
Good info! Thanks for following up!
J.
Caldina powered...
lumbercis
Postby st185-sainz » Sun Nov 27, 2011 11:54 am
doesn't have the RAV4 a torsen LSD?
If you need a GT4 torsen unit with stub axles just get me an email, I have plenty of them at home as I did some plated LSD upgrades for GT4...
my email: mario.koenig@gmx.at
Mario,
ST205 blue: completely stock
ST185CS (white): white - gravel/snow spec, dog box, TRD clutch, uprated turbo, lightened flywheel, uprated actuator, cold air intake, ST182 cams, walbro pump, batt relocation, forgies, programmable ECU (dyno), ...
st185-sainz
Postby CMS-GT4 » Tue Nov 29, 2011 7:03 pm
From what I have read, the rear torsen was a TRD upgrade item in the US, so most likely do not have it.
