Issue with new alltrac
Postby crazyceli25 » Sun Dec 25, 2011 3:18 pm
I finally got my new alltrac.
It's a 1992 runs pretty good
Gonna need some work in the engine
Department but at least the body is
Straight. Anyway, I have it parked in a big pile
Of snow. I was trying to move it the other day
And only the left front and right rear tires were
Spinning. Just wanted to see if these alltracs
Had common problems like that. Hoping I can
Just change the fluid in the trans and diff
And I'll be ok. Any ideas?
crazyceli25
Re: Issue with new alltrac
Postby d1alltrac » Mon Dec 26, 2011 2:01 am
This is not an issue or a problem. The car has open front and rear differentials and a viscous center LSD.
You will need to install a rear limited slip differential in order to get power to both rear wheels, there is no front LSD (that I know of) available for our cars at this time. (some 185's and all 205's have a factory torsen rear LSD)
Patrick R.
88 ST165 x2
92 MR2 turbo
02 330i
d1alltrac
