What are the weak links in the drivetrain?
Postby dragstang86 » Thu Feb 09, 2012 5:06 pm
Ok what are the week links in the drivetrain and about how much power are they typically reliable until? Mine when done should make 500-550 awhp and I would like to be able to launch it hard. ST205 diff and stock axles hold up? What is the stock driveshaft good for? Trans? Does anybody make aftermarket axles for these cars? Its a ST185 btw.
92 All trac
dragstang86
Re: What are the weak links in the drivetrain?
Postby lumbercis » Thu Feb 09, 2012 6:49 pm
Honestly, I doubt anyone has ever launched an alltrac hard with that kind of power. Most of the high power guys like Pat or Trevor leave soft on street tires to avoid breaking the drivetrain. Mostly because we don't have a lot of beefier aftermarket options.
There's a guy in Greece doing 9.2ET's using a dogbox (check the racing forum for thread), but he's not on the forums so not a ton of details on his setup.
Caldina powered...
lumbercis
Postby Mafix » Tue Feb 14, 2012 5:49 pm
the vc and the clutch are the weak link.
Postby tubasteve » Tue Feb 14, 2012 9:30 pm
Mafix wrote:the vc and the clutch are the weak link.
...and some drivers....
tubasteve
Postby sleeper » Tue Feb 14, 2012 11:32 pm
The stock rear diff is a WEAK link! i have seen several of them die on 350 hp cars with an aggressive clutch ( often taking the gearbox with it to the afterlife!)
So this is the first thing you need to change.
Next thing you MIGHT brake is the gearbox itself ( syncros, or forks. ) But this is not really from the power, it`S more from abuse.. you do need to use the clutch when changin gears with these gearboxes.
My tip would be to get a st205 gearbox, since they do have alot better syncros and forks.
I have also seen a few center diffs not working as they should, due to they starting to get old.. you could "weld" it as me and another guy here on the forum did, but you have to be carefull when parking in tight spaces..( the other guy here on the forum killed the center diff when parking?, but mine have been ok for about a year ( with alot of hp..)
Other than that, you should be safe for whatever power you can trow at it... i have yet to see a gearbox, driveshaft or axels get broken due to hp\tq. So this isn`t really something you have to worry about. Just remember to take up the slack before you launch it.. ( like you have to do in every other 4wd car.. )
PS: the guy from greece also have a low 10 sec car running a stock 205 gearbox..
sleeper
Postby dragstang86 » Tue Feb 14, 2012 11:37 pm
sleeper wrote:The stock rear diff is a WEAK link! i have seen several of them die on 350 hp cars with an aggressive clutch ( often taking the gearbox with it to the afterlife!)
Thanks for the input. Is the ST205 rear diff much stronger? My plan as far as the trans goes....I have free access to a 2wd dyno at my shop so I was going to use the ST185 trans in 2wd mode to get the tune close and get any issues figured out with no fear of breaking it. Once I get any issues figured out, swap it out for a ST205 trans. It's good to hear the axles and driveshafts hold up well. They were my big concern.
92 All trac
dragstang86
Postby sleeper » Tue Feb 14, 2012 11:56 pm
Think you forgot to write something dragstang..
sleeper
Postby dragstang86 » Wed Feb 15, 2012 12:08 am
wtf? I don't know where it went but I definitely wrote something! I'll try this again...
Thanks for the good info. How strong is the ST205 rear diff? It is good to hear that the axles and driveshaft holds up in them. My plan with the trans is to use the ST185 initially because I have a 2wd dyno that I have free access to so I plan on using the ST185 trans in 2wd mode to get the tune close and workout any issues and not be worried about if I break it. Once I get any issues straightened out I will pull it and swap it with a 205 trans.
92 All trac
dragstang86
Postby sleeper » Wed Feb 15, 2012 12:45 am
dragstang86 wrote:wtf? I don't know where it went but I definitely wrote something! I'll try this again...
The st205 rear diff is REALLY weak.. ( your options are either to weld it ( makes it alot stronger since it`S the thorsen unit itself that is the weak link) or get a cusco unit.)
As soon as you get a aggressive clutch and do some hard launches it will brake.. ( and it will be 50-50 if it takes the gearbox with it, due to the rear diff locking up)
There is a guy here with a (tjdubble07) who tuned his high hp car in 2wd mode, and if i`m not remembering wrong, he found out that the gearbox would take about 500ft punds before it broke in fwd mode.
sleeper
Postby klue » Wed Feb 15, 2012 12:58 am
Diff is definitely going to be weak spot
Postby tubasteve » Wed Feb 15, 2012 1:38 am
klue wrote:Diff is definitely going to be weak spot
Agree...dumb answer from me, but which diff ;-), aka all.
tubasteve
Postby dragstang86 » Wed Feb 15, 2012 2:11 am
I don't want to sacrifice the street ability and the fun on the back roads by welding it so it looks like the Cusco unit is my only option. After a quick google search its not cheap either! The one I found was over $1600 and thats before out of country shipping! Ouch!
92 All trac
dragstang86
Postby lumbercis » Wed Feb 15, 2012 4:26 am
@sleeper
Define "really weak"? At what whp have you broken ST205 diffs? I agree that a Cusco would be stronger, but depending on where dragstang is at right now it might be worth it for him to put in a Torsen until he's making enough power to need a Cusco. :shrug:
Caldina powered...
lumbercis
Postby sleeper » Wed Feb 15, 2012 9:04 am
dragstang86 wrote:I don't want to sacrifice the street ability and the fun on the back roads by welding it so it looks like the Cusco unit is my only option. After a quick google search its not cheap either! The one I found was over $1600 and thats before out of country shipping! Ouch!
I think you will be surprised with how little you would notice a welded rear diff in this kind of car.. I`m using my car on road courses to, and even with a locked center and welded rear i don`t notice anything bad about it other than when i`m under 10mph.. ( it`s actually more stable now since i know what it will do under hard driving, not like before when i had all diffs open.. )
sleeper
Postby sleeper » Wed Feb 15, 2012 9:09 am
lumbercis wrote:@sleeper
Well, i`v seen the brake at 300awhp and up. But i have also seen them take 450awhp without braking.
It`s not so much the power itself, but the use..
You won`t be able to kill it with a stock\mild clutch... but as soon as you get a aggressive clutch and launch it.. you should worry about it.
BTW: The 185 rear diff have the same problem.
sleeper
