ST205 rear diff
ST205 rear diff
Postby temperacerguy » Mon Mar 05, 2012 10:11 pm
OK, question of those who know more than me..
Did All ST205s (regardless of market) come with the rear torsen LSD?
Or was this an option?
And the ST205 and ST185 Torsen Rear diff are the same correct?
Re: ST205 rear diff
Postby klue » Tue Mar 06, 2012 3:11 am
all had em if im not mistaken
Re: ST205 rear diff
Postby alltracman78 » Tue Mar 06, 2012 12:45 pm
All 205s had rear TORSEN and it's the same as the 185 homologation TORSENs.
Also, FYI you don't have to get different rear axle stubs, the difference between the 2 is just the clip on the end that holds them in.
Open diffs have a pull off clip [you remove the rear cover and pull the clip off of the stub] while TORSENs have a pop out clip like the front stubs [not sure if the front clips would work on the rears or not].
