any info on making 90 all-trac rwd
Postby darkcloud350 » Sun Apr 29, 2012 9:52 pm
to start off I don't want to hear bad talk or anything of the sort on this topic. I am for real and serious on this.
I have lost my shift forks in my stock trans so now I want to open my mind for drifting my 300zx has bored me and I love my all-trac more.
this topic is informative only we all know blah blah keep it awd but honestly I see this more to be fun and helpful to all others that have had this thought in mind.
Any info will help. Such as
what transmission can mate the 3sgte that can handle rwd
What can you do to the stock trans that can either make it fwd or rwd
If someone has already converted what have they done
I myself plan on only having rwd for one summer event then going back to awd but for now this is big.
If other topic threads have already started this im sorry I tried looking and all have said only negative stuff
darkcloud350
Re: any info on making 90 all-trac rwd
Postby RafaCalde » Mon Apr 30, 2012 1:54 pm
well, i think to start, one has to rotate the engine. i've never heard a transverse mounted transmission being rwd only. definitely not gonna be able to do it with the E series transmission
Rafa
RafaCalde
Postby rallygarage » Mon Apr 30, 2012 1:58 pm
A dog transmission is stronger.
rallygarage
Postby CMS-GT4 » Mon Apr 30, 2012 2:36 pm
Toy sport ha info on gearboxes that bolt up. You will need to turn the engine as well as install it at the correct angle. You also need a solution for the front wheel bearings. You may also need a new steering rack depending how everything fits. If your serious start a build thread and get to cracking. Justin Simpson has a v8 Rwd gtfour. His build is online in a Lexus forums and he has lots of pics on photobucket.
Postby UtahSleeper » Mon Apr 30, 2012 3:32 pm
Small thing. Distributor will probably have to be removed to get the engine close to the firewall.
In corollas people put the W58's, I believe, or R154. It was a late supra transmission. Also the Beams motor in the RWD cars used a 6 speed. I imagine that could be adapted too.
Curious on how much you would have to change to make something like this work. And how hard would it be to return it to stock afterwards.
UtahSleeper
Postby phattyduck » Mon Apr 30, 2012 3:52 pm
RWD with stock configuration: Weld some diffs, remove axles but leave stubs - done.
RWD with longitudinal configuration - tons of work... relocate steering rack, create trans tunnel, etc. At least there is a rear diff there, but it probably wouldn't like handling full power for long and would also require an upgrade.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby CMS-GT4 » Mon Apr 30, 2012 4:00 pm
So how is welding diffs making this thing rwd? I never understood how the whole process of that worked. I know some of the suby guys do that. The thing that sucks about that is your dragging around the weight of that transfercase using that process.
Postby underscore » Mon Apr 30, 2012 4:03 pm
^ you're jamming the center diff so all the power goes out the rear.
darkcloud350 wrote:I myself plan on only having rwd for one summer event then going back to awd but for now this is big.
if it's for only one summer I'd say you're gonna want to only weld the diffs, remove the front axles leaving the stubs up front and replace all those bits when you go back to AWD, if you flip the motor you're looking at a lot of cutting and welding and you likely won't be able to bring the car back to AWD. I know of two local Subarus that got converted to RWD using roughly the above method, one was such a pain that it went through 3 owners before someone switched it back to AWD, the other is actually a fairly capable drift car but it too has it's issues and took the owner a few years to get it decently stable.
Another option is of course to buy a wrecked MR2 and a GT-S with a blown motor, and put the MR2 rear end into the GT-S, thus making an MR Celica. Another local did that with an 80's Accord and it was apparently a very controllable drift car.
Postby l0ch0w » Mon Apr 30, 2012 4:34 pm
Can I be the first one to just come out and say that this is a dumb idea...
OP has 14 posts on this forum, and I would venture a bet that he is being a troll...
For the money you will spend on converting your car, you might as well go buy a 240sx, or a trueno...
Andrew
1991 Red Alltrac
l0ch0w
Postby lumbercis » Mon Apr 30, 2012 5:06 pm
^I was trying to resist. :evil:
Caldina powered...
lumbercis
Postby UtahSleeper » Mon Apr 30, 2012 5:10 pm
l0ch0w wrote:Can I be the first one to just come out and say that this is a dumb idea...
He might be who knows. I took from his starting post here that he has searched and read various posts here, which is why he requested no flaming and such. Just a solid conversation. And the fact there have been 5th gens coverted to rwd, I felt it was a worth while discussion. Plus, when you start saying everything that has to be done, some will step away from the idea.
UtahSleeper
Postby WarTowels » Mon Apr 30, 2012 5:39 pm
Cut the front axles in half. :lol:
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby Dracov » Mon Apr 30, 2012 6:35 pm
If he really is serious about this, then let's sit back and see if he'll dump the $10,000 into chassis and drivetrain work that will will inevitably require. As mentioned there is a V8 RWD Celica...and from what I know of it, no expense was spared in the build. This is territory few even consider, much less trailblaze through so this will be something worth posting in detail if it happens.
If it doesn't happen, c'est la vie. It will then go into the archives alongside the dozens of "how do i make my Celica a Alltrack?!" posts we get each year.
1988 Toyota Celica Alltrac
Dracov
Postby UtahSleeper » Mon Apr 30, 2012 6:44 pm
Dracov wrote:If it doesn't happen, c'est la vie. It will then go into the archives alongside the dozens of "how do i make my Celica a Alltrack?!" posts we get each year.
+1
UtahSleeper
Postby underscore » Mon Apr 30, 2012 6:48 pm
You can do it pretty cheaply I would think, if you leave everything mounted as is but take apart the front axles and weld the diffs. You'll likely be losing a lot of power through the drivetrain vs a typical RWD setup, but it can be done without re-mounting the engine and finding a different tranny etc.
edit: see http://driftunion.com/blog/?page_id=54
