Anyone using/used OS Giken OR Exedy clutchs
Postby 4rsnduction » Thu Jul 26, 2012 11:20 am
As the title says
Is anyone using or have used a OS GIKEN clutch or Exedy clutch ?
What type was it ?
How did you find it ?
Im hunting a new clutch while my box is apart, any feedback is much appreciated.
4rsnduction
Re: Anyone using/used OS Giken OR Exedy clutchs
Postby Hotrodhendrix » Thu Jul 26, 2012 1:26 pm
I used the OS Giken aluminum (gold in color) twin plate. It was amazingly friendly and with a very light peddle. (I use slave extension) Of course it had the twin plate clatter but it was a bit louder than most. Held my power fine but it was way over rated for what I was actually pushing.
Downside. Waiting/ finding parts. right hand drive has replacement discs and bearings.
I ended up moving down to something closer to my power needs. Clutchmasters street/strip single. No more clatter but the peddle is more firm.
~James
Postby underscore » Thu Jul 26, 2012 3:06 pm
I've got an OS Giken SS sitting in a box from someone on here, I forget who though.
Postby Terracar » Thu Jul 26, 2012 6:57 pm
Coery Darling was running an OS Giken single plate. You may want to PM him.
-Terracar
Terracar
Postby Awesome-Trac » Thu Jul 26, 2012 11:41 pm
Running a EXEDY clutch which I got through my company, I have no complaints
•Daniel
Awesome-Trac
Postby 4rsnduction » Fri Jul 27, 2012 1:38 am
awesome-trac wrote:Running a EXEDY clutch which I got through my company, I have no complaints
Which clutch are u using ?
How does it feel ?
How long has it been in the car ?
4rsnduction
Postby Nitro_Alltrac » Fri Jul 27, 2012 1:46 am
The previous owner of mine had installed an Exedy. Not sure which one but it has always felt really good and works great. Right now it's got around 110K miles and it still feels as good as it did when I got the car six years ago.
Mike
92 All Trac - Daily Driver
Nitro_Alltrac
Postby Awesome-Trac » Fri Jul 27, 2012 2:38 am
How does it feel ?
Oem spec and it feels great, ive had it on my car for about 2 month but I don't push my car at all tho
•Daniel
Awesome-Trac
Postby 4rsnduction » Fri Jul 27, 2012 4:26 am
Thank you to everyone for your descriptions.
These are the clutches im looking at, depending on the price of the OS Giken kit depends on what i buy.
The exedy clutch kit will only cost $500 (plus $350 for a lightweight flywheel from somewhere else)
Does anyone have any thoughts ?
4rsnduction
Postby 94 MR2 Turbo » Wed Dec 26, 2012 6:57 pm
im using an ORC single plate. i got it used from a board member. It does take a while to get parts for this setup but its worth it. It is VERY noisy when its depressed but you get use to it. Sounds like a ducati. =) pedal is light as stock and should hold good power. It does take some getting use to but after that learing curve its ok. The lightend flywheel makes it hard to start off.
I hope this helps..
94 MR2 Turbo
Postby lumbercis » Wed Dec 26, 2012 9:44 pm
I've used Exedy 3-puck and twin disk clutches. Never had a problem with either. Neither one had any clutch rattle. Those are both fairly aggressive so more difficult to drive. The full face or 6 puck should be much easier to drive.
Caldina powered...
lumbercis
Postby 4rsnduction » Wed Dec 26, 2012 10:01 pm
Thank you for your reply's.
I purchased the exeddy clutch pictured back in august, close enough to 5 months ago.
4rsnduction
Postby warracer » Sun Dec 30, 2012 4:48 am
I have an Exedy Stage 2 Clutch, I love it, extremely smooth for daily driving , but still has small room for the friction point, its linear and bites back like crazy when you want :D
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Postby Pavlik185 » Fri Jan 25, 2013 9:30 pm
Going to use a Exedy clutch TH02SD
http://www.exedy-racing.com/racing/ja/pro/hy_single.html
Maybe somebody has experience usign this clutch set? Any opinion? Thanks!
Pavlik185
Users browsing this forum: nelfreds and 2 guests
