Wheel bearings replaced...still slight play?
Postby toayoztan » Sat Jul 28, 2012 8:06 am
So about a few months ago, I changed all four wheel bearings. As you know, my car is completely gutted, no drivetrain/power train, so the car weighs nothing.
After replacing the wheel bearings, I put the suspension back together, threw the wheels on, and let the car sit on all four wheels (never rolled), WITHOUT axles in place.
Today, I change my wheels out for newer ones I bought a while back, and I noticed all the wheels had very slight play at 12 and 6 position...very very very slight, but it's there. No play at all in the 3 to 9 position that I could tell. The wheel/bearing rotates smoothly of course, no noise I hear and no hesitation/friction I can feel that would make me suspicious.
I've never noticed this before, but I have never tested any play before with wheels on, just only grabbing the hub itself without wheels or rotors.
Am I missing something here? Do the axles in place secure the whole assembly better, then I should test it?
Or did having no axles in the wheel bearings caused some kind of pressure and premature wear on the bearings?
I doubt my wheel bearings are bad, and like i said, i noticed no play immediately after installing the bearings and hub right after I pressed them in.
I'm thinking the weight of the wheels themselves is causing the very very minimal play i'm experiencing. I've replaced wheel bearings before without issues.
I'm guessing I shouldn't worry about it, and recheck once the axles and all are in place, but I'm just getting a little anxious about this..
Thanks!
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Re: Wheel bearings replaced...still slight play?
Postby BoostedBlueToyotas » Sat Jul 28, 2012 9:42 am
Think the BGB states that you should have the axles in place with a load on the suspension. I remember going out of the way to have mine in when my car was gutted. I can remember tying up the halfshafts so the end going into the tranny was out of the way in the engine bay when I rebuilt my car. I think that there is an SST to use as a replacement for the axles if I remember right.
Tim Plessing
Columbia, MD
BoostedBlueToyotas
Postby bridge47 » Sat Jul 28, 2012 10:29 am
I doubt you did any harm.
Axles back in and re-check.
Facts are stubborn things.
bridge47
Postby alltracman78 » Thu Aug 09, 2012 2:03 pm
He probably did.
Even setting the knuckles down without having an axle inside usually warps them.
This is why I have spare axles that are cut off at the joint, so I can stick them in the knuckle to support the bearing.
Postby toayoztan » Thu Aug 09, 2012 4:15 pm
Would the hubs and/or knuckles be ruined too?
I've never had issues before and with other cars about not having axles in place. I put new wheel bearings on the alltrac, and just dropped it down, maybe rolled it a few feet back and forth.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby phattyduck » Thu Aug 09, 2012 5:18 pm
Its debatable whether you caused damage (I'm not sure one way or the other).... but I will guarantee that you need to put an axle in there to preload the bearing before you check if it is tight.
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby toayoztan » Thu Aug 09, 2012 5:24 pm
Yeah, last week, I torqued down my axles in there, however I didn't jack up the car when doing this (didn't cross my mind until now, I was in a rush :doh:).
So now, if the wheel bearings really were actually damaged, they may now be damaged more. However, more than likely, it really just suggest that the axles and wheel bearing is not clamped down properly since there was load on the wheel bearing by the weight of the car with the wheel on and on the ground.
I'll probably go back, remove the wheels, then loosen up the axles, retorque the axles, then put the wheel back on, and call it. I'll check any play after retorquing the axles.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby phattyduck » Thu Aug 09, 2012 5:54 pm
I've always torqued axle nuts on the ground. It'll be similar to wheel nuts - snug as tight as you can off the ground, then torque once you are on the ground. The tire will give you all the play you need. Without a helper, its about the only way to do it without risking damage to your wheel studs, etc.
Remember that the axle nuts/wheel bearings/etc. have much more force on them when you are driving...
phattyduck
Postby aus jd 2703 » Fri Aug 10, 2012 6:52 am
You possibly could have light brinelling damage but given the car didn't move and the problem your describing isn't bearing damage.
Correct procedure is wheels off the car and foot on brake while torquing this should give the truest reading. All the axle does is pre load the bearing. So not having the axles in for a small time with no movement shouldn't damage anything.
aus jd 2703
Postby toayoztan » Sat Aug 11, 2012 6:50 am
When you say no movement, do you mean NO movement? Because I did roll it back and forth about 5-10 feet a few times, but that's it.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby esracing » Sat Aug 11, 2012 11:25 am
My 2 centsToyota master tech here.yes you should of put axles in.i think your bearing will be fine .put the axles in now .what i do when axles are out i put a large bolt and washes and nut to hold it together so that way you can roll the car around and it won't come apart.
2008 tundra blue
1988 st165 white imsa gto
1969 camaro 502 bb 630 hp black
esracing
Postby aus jd 2703 » Sat Aug 11, 2012 10:52 pm
Any one who has had to remove the stub axle from the bearings would know they arnt gOing any where your fine move on ur problem is else where
aus jd 2703
