flywheel weights?
flywheel weights?
Postby Shafer777 » Sun Jul 29, 2012 7:18 pm
so i have an 88 all trac with a st185 mr2 swap running on 20lbs. well lately my clutch has been lightly fading away on me, crusing down the highway at about 3k and roll onto it and around 15-16lbs the engine will get faster, but im not moving much faster lol.
i was planning on replacing my mystery clutch with something equivalent with a stage 3-4, and getting rid of my heavy, slow reving flywheel with something much lighter that lets it rev free-er/faster, and lets my turbo spool faster in lower gears, maybe some wheel spin in there too :wink: i was just wondering on how many lb flywhel i should look for. and IMO it cant rev too fast :)
Shafer777
Re: flywheel weights?
Postby 4rsnduction » Sun Jul 29, 2012 10:17 pm
I use a 4.4kg chromolly flywheel
Use a pound to kg calculator to work it out, as i have no idea :lol:
Its noticeable over a stock unit but alot easier to stall the car with a non organic-disc type clutch
4rsnduction
Postby aus jd 2703 » Sun Jul 29, 2012 10:22 pm
i spoke to a respected clutch guy last week about light fly wheels and he is of the opinion on a turbo car especially awd, you want all the momentum you can to help keep the engine spinning (minimize lag) during gear shifts. made sense to me at the time, if it was a light weight NA car sure go for it but not a heavy awd
aus jd 2703
Postby toayoztan » Mon Jul 30, 2012 4:17 am
Yeah, i've generally heard on AWD (I'm personally not sure on the turbo aspect of it) that you really want to avoid a lightened flywheel if possible.
Maybe you can go lighter, but I don't think you want like a 10.5lb FW.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby Corey » Mon Jul 30, 2012 2:13 pm
Having driven the stock, ORC and now a 9 lb ACT Light weight flywheels, I can say that in my opinion - lighter is definitely the way to go.
I did notice that with the ORC clutch (which is lighter than stock, but heavier than the ACT), that the revs do drop fast when shifting.
But for the ACT install, I also went to a MAP system with no AFM so the engine breaths so much better, the revs actually hang a bit now so no change in upshifts, but downshifts are fantastic - the engine revs freely now.
Corey
Images: 50
