outboard cv joint
outboard cv joint
Postby l00k0v3rth3r3 » Wed Sep 12, 2012 6:01 am
is there a trick to getting the outboard cv joint off? I've been using the bgb, but i got a little lost...i have the inner snap ring off, the inboard cv off, the boots off and im not sure how or if the outboard cv comes off. any help is appreciated
Gabe
1990 Maroon Audi 90 Quattro
1998 Toyota 4runner Limited
1991 Mazda Miata 1.8l
1953 Dodge B4B 1/2 Ton Pick up - Currently Lawn Art
l00k0v3rth3r3
Re: outboard cv joint
Postby l00k0v3rth3r3 » Wed Sep 12, 2012 6:53 pm
bump
Gabe
l00k0v3rth3r3
Postby jaydog82 » Wed Sep 12, 2012 8:09 pm
I have rebuilt the st165 axers, can u post a pic of the part?
jaydog82
Postby fussellbug » Wed Sep 12, 2012 8:45 pm
The BGB for 1993 Celica says in bold letters: "NOTICE: Do not disassemble the outboard Joint."
I'm pretty sure it is possible to disassemble this joint for overhaul (aftermarket rebuilders do) but I'm guessing Toyota intended for it to be replaced as an assembly with the shaft. The EPC also shows all of the outer joints sold assembled to the shaft.
fussellbug
Images: 36
Postby l00k0v3rth3r3 » Wed Sep 12, 2012 11:31 pm
its not imperative that i get the outboard cv off, for this case...but i need to change the boots on my other trac as well, and it appears there is a damper on the shaft and i have no idea how i will get the boot over it..so i was looking for some practice removing the one for the car that doesn't run currently.
all the cv joints are in good working order.. i just wanted to get more familiar with it
Gabe
l00k0v3rth3r3
Postby 88gt4DE » Thu Sep 13, 2012 12:21 am
All the ones I have done you assemble from inside out and leave outer joint in place ...
Postby l00k0v3rth3r3 » Thu Sep 13, 2012 12:38 am
then that is what i will do...thank you everyone for the advice
Gabe
l00k0v3rth3r3
