Rear diff kit installation tricks
Postby underscore » Thu Oct 25, 2012 3:52 am
Not all of us have presses or money to burn, so post up any tips or tricks on how to get the old bushings out and the ones from Luke/Mario/whoever installed.
What's worked for me thus far tonight:
To remove the two smaller bushings, get a medium/smallish flat screwdriver or wedge, and a large flat screwdriver or wedge, a bigass hammer, some sockets and a long bolt. If you have a vice then awesome, if not brace it with your foot or whatever (but be careful not to hurt yourself)
Flip the bracket thing around so the more open end of the bushing is facing you. You can now see the metal tube where it curls over and sits flush with the bracket. Hammer the small screwdriver between the bushing sleeve and the bracket until they start to separate a bit (I found it was easiest to start where the two halves of the sleeve meet). Get the big screwdriver and hammer it in there, rotating it around until that half of the sleeve is as far out as it will go with that screwdriver. Repeat for the other half.
Now flip the bracket on its side, pick a socket that has roughly the same outer diameter as the metal tube on the inside of the bushing. Put the bolt through the socket and through the bushing, to hold the socket in place. Brace the bracket and beat the snot out of the socket, after a few good hits it should pop the old bushing free (it may shoot halfway across your garage when it does come free).
I've started trying this with the bigger bushings but I think I need a larger wedge to get the sleeve further out because it won't budge. That or a bigger hammer.
Postby celigts » Thu Oct 25, 2012 10:41 am
Why not do what some have done and burn it out
3SGTE project motor very slow
celigts
Re: Rear diff kit installation tricks
Postby l00k0v3rth3r3 » Thu Oct 25, 2012 11:21 am
i found that getting the old one out...for the big one at least its easiest to push the metal sleeve out first. Burn it and get in there with a small sharp knife and cut the four rubber areas that hold it in there, then beat the piss out of it with your socket... I personally used a socket with an extension. When getting the half metal outer sleeves out just use a screwdriver and hammer, separate the lip from the housing and then come at it from the back end. To get the bigger one in I used the axle nut socket ( the big mother fucker ) with a long 1/2" drive extension + a ton of grease. hope that helps
also once the old ones are out take wd40 or deep creep or whatever penetrating oil you use and clean the inner diameter of the bushing housing
Gabe
1990 Maroon Audi 90 Quattro
1998 Toyota 4runner Limited
1991 Mazda Miata 1.8l
l00k0v3rth3r3
Postby Mafix » Thu Oct 25, 2012 11:54 am
air hammer and a torch. and the 4 big ones are a bitch. we did one set without a torch or an air hammer. it took forever.
Postby underscore » Thu Oct 25, 2012 1:10 pm
Oooh air hammer, good idea. What area did you torch? The subframe, or the rubber guts of the old bushing?
l00k0v3rth3r3 good idea about cutting out the center. I tried hammering on the sleeves from the backside though and I think I started to damage the subframe so I stopped. Although I assume it would move more freely with the center out.
Postby celigts » Thu Oct 25, 2012 1:41 pm
Oh man air hammer sounds like a magical tool! I will use that for sure.
celigts
Postby l00k0v3rth3r3 » Thu Oct 25, 2012 1:58 pm
underscore wrote:Oooh air hammer, good idea. What area did you torch? The subframe, or the rubber guts of the old bushing?
it basically falls out once you get the center out
Gabe
l00k0v3rth3r3
Postby underscore » Fri Oct 26, 2012 2:36 am
Update:
I managed to get all four big ones out, after a few herp derp moments with a bolt type puller I can now pop them out in a couple of minutes each. I basically did the same thing as above, little screwdriver then big screwdriver to pry it out as far as I can, then I took a 27mm socket and put a bolt through it backwards (so the open end faces you) and bolted the socket onto the bushing. This kept it from jumping off and seemed to transfer the energy better. Then I soaked WD40 down between the sleeve and the subframe, let it sit for a minute to soak down, and then beat the piss out of it. 4 good whacks and out they came. I'm pretty sure the WD40 helped because the sides of the subframe and sleeve were covered in it when they popped apart.
Postby underscore » Fri Oct 26, 2012 2:37 am
Now I just ned to find the best way to clean up and protect the rear subframe and pop the new bushings in.
Postby celigts » Fri Oct 26, 2012 2:49 am
Por15 :) the rock guard. If I had the time I would do it that way
celigts
Postby celigts » Fri Oct 26, 2012 2:32 pm
Well tonight's the night for getting this done. Will anyone be able to help me quickly if I'm in need of it? And the tapered cap goes on the bottom correct? Does it matter for the small bushings what side the cap goes on?
celigts
Postby underscore » Fri Oct 26, 2012 2:48 pm
I haven't gotten that far yet, I was gonna ask Luke which end goes where.
Postby l00k0v3rth3r3 » Fri Oct 26, 2012 2:56 pm
it doesnt but i would do cap on the bottom... it'll be easier when you put the subframe back in. and celigts you will have a PM
Gabe
l00k0v3rth3r3
Postby celigts » Fri Oct 26, 2012 4:11 pm
For your pm :D ill try taking lots of pics and posting them here for reference to anyone who will feel better doing it with pics. I love pics!
celigts
Postby underscore » Fri Oct 26, 2012 4:15 pm
I love them too but I suck at taking them, usually cause everything ends up dirty as hell and I don't want to ruin my camera.
