TRD front and center diffs
Postby BADNEWS » Mon Nov 12, 2012 6:19 am
ok so I've been doing some research and have came to the conclusion that Kaaz made the front/center lsd's for TRD. Here is some pictures of the TRD diffs taken apart:
Center lsd on the right. Center Viscous Coupling unit (aka vc) replaced with clutch pack front lsd on the left:
front diff looking at where the shafts that connect everything. Outer/Biggest diameter shaft transfers power from the center diff to the rear diff via transfer gears. The middle shaft takes power from the center diff lsd to the front diff lsd. And the inner/smallest shaft gives power out to the front left wheel from the front lsd:
vc carrier which is now the front diff carrier apart showing front diff housing:
front diff housing opened up showing discs and 4 spider, lower left in 2nd pic and middle of 3rd:
center diff opened up showing discs:
4 spider center diff:
Everything laid out. You can see there is like a bearing for the spider gears of the center diff to rotate, on the right shaft of the 3 in the first picture
So as you can see you would never be able to buy just a front or center lsd from TRD. They were all sold as one unit part#41035-ST010 for a price of 370,000 yen. Which would equal $4,655 right now. And this has been discontinued for years so the price may of even been higher now if it was still available.
Now look at these discs from the trd lsd's:
this was from a honda guy comparing lsd's.
Kaaz disc on the left next to a Os Giken disc on the right
So I think Kaaz was the developer and producer of the TRD GT-4 front and center LSD's
865AWHP, 591 torque
BADNEWS
Re: TRD front and center diffs
Postby underscore » Mon Nov 12, 2012 6:29 am
Have you tried to contact Kaaz to see if any of this is true?
Postby BADNEWS » Mon Nov 12, 2012 6:50 am
underscore wrote:Have you tried to contact Kaaz to see if any of this is true?
No, just research it now and shared it with you guys.
865AWHP, 591 torque
BADNEWS
Postby BADNEWS » Mon Nov 12, 2012 1:38 pm
You can see the parts look identical here too. This is a pic showing all the pieces of a kaaz
You can see the cusco plate grooves are on a different angle.
here is from a Corolla AE86. left is stock, middle is TRD/Kaaz, right is Cusco:
full write up here:
http://orangeadvan.blogspot.com/2008/07/stuck-on-lsd.html
another cusco disc pic:
MAXGRIP by Weir Performance
865AWHP, 591 torque
BADNEWS
Postby athousandleaves » Mon Nov 12, 2012 5:12 pm
Not sure if any of you guys saw/remember this but that white Alltrac that showed up on eBay a while ago with the owner claiming it was a race car made by Toyota with upgraded diffs was covered with Kaaz decals. I think I tried researching if they had ever made anything fo our car and found they hadn't so I assumed he wasn't correct in his assumptions about the diffs.
Looks like it may hve had the TRD/Kaaz upgraded diffs after all.
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby yota 3.0 » Mon Nov 12, 2012 8:00 pm
wow great info and research man! its too bad all of this is so rare.
James
yota 3.0
Postby CMS-GT4 » Mon Nov 12, 2012 8:30 pm
That thing is a work of art. Shame I did not think to buy it when I got my car.
Postby athousandleaves » Mon Nov 12, 2012 8:52 pm
Can anyone recall what killed that TRD diff pictured above?
I feel like it was in a Russian car that got in a fight with a tow truck?
1992 White turbo4WD
athousandleaves
Postby aus jd 2703 » Mon Nov 12, 2012 9:30 pm
least that diff shows how its done now we just need some one to re-manufacture it....
aus jd 2703
Postby BADNEWS » Mon Nov 12, 2012 9:44 pm
aus jd 2703 wrote:least that diff shows how its done now we just need some one to re-manufacture it....
Goodluck. That is 2 diffs, One that needs 2 housings made for it (Front diff), and custom shafts made to transfer the power back and forth. To do something like this is a ton of money! I'm having a hard time generating interest for a front and center diff combo where the guy thinks he can do it for a far more reasonable price. I talked to him today to see if it is possible for just a front diff since it doesn't seem like people want the center upgraded. He is looking into our options.
Personally I have been looking into what EVO's are doing. They do a Helical (Quaife style) Front LSD that is in the transfer case. Just like how the TRD one is. Then a Helical (Quaife style) Center LSD which is in the main transmission. And run a clutch type Rear LSD.
So if we can get people on board for this, I can see what he thinks it'll cost. Should I even ask? I can tell you it'll be big $$$ but Pat (Alltrac101) and I are already in. We need like 2 or 3 more guys to make this happen.
865AWHP, 591 torque
BADNEWS
Postby klue » Mon Nov 12, 2012 9:51 pm
clutches take up to much space IMO leading to smaller, weaker sub components. I want some big as gears in there that go HIYAH when the kick in
Postby CMS-GT4 » Mon Nov 12, 2012 10:53 pm
For as expensive this is all getting, I still wonder the cost in adapting an evo gearbox and rear dif.
Postby athousandleaves » Mon Nov 12, 2012 11:26 pm
CMS-GT4 wrote:For as expensive this is all getting, I still wonder the cost in adapting an evo gearbox and rear dif.
+1
Didn't the evos and ST205's both use the XTrac 532 6-Speed gearbox for rallye anyway? Are we the same bellhousing pattern?
And yeah, my car could do with a good ol' HIYAH!
1992 White turbo4WD
athousandleaves
Postby BADNEWS » Mon Nov 12, 2012 11:46 pm
I doubt that would be cheaper. Plus all the upgrades it needs to handle the power.
865AWHP, 591 torque
BADNEWS
Postby CMS-GT4 » Tue Nov 13, 2012 12:03 am
+1
Needs an adapter plate I think, and possibly a custom clutch. Then there is the needed mounts and axle adapting. Plus, if I was to ever do this, I would upgrade the front system to handle the power. There are some places online that offer the parts. I think it would be in the 7k range to do.
