Flywheel Lock
Flywheel Lock
Postby dkdmonk » Mon Dec 17, 2012 4:00 am
Just wondering what you guys use to lock the flywheel in place?
I need to pull the flywheel to have it resurfaced and I have the timing belt off so I'm hoping I can get a tool somewhere. Unless you guys have some magic way of doing this.
I was going to pick this one up http://www.youtube.com/watch?v=RTTvD14PoDU but it might be over kill :lol:
Thanks,
dkdmonk
Images: 12
Re: Flywheel Lock
Postby toayoztan » Mon Dec 17, 2012 4:34 am
Are you looking for a way to hold the flywheel in place to remove the bolts and keep the timing true?
If your motor is OEM spec, head/valves/pistons, etc. the motor is non-interference and spinning the crank will not damage or hit the valves.
If you're looking for a way to just hold the flywheel still so you can actually remove the bolts by hand (obviously, an air gun would be best here), you can use the tool below too.
There are universal ones out there, online or in stores, if you really want to keep your timing in order.
http://www.dealparts.com/product/00-500 ... PAodTXkAYA
http://www.ecrater.com/p/10635909/unive ... 4750?gps=1
http://www.handsontools.com/Klann-Tools ... paign=BROI
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Re: Flywheel Lock
Postby ___Scott___ » Mon Dec 17, 2012 5:06 am
This worked well for me:
I don't remember which bolt/nut I used, but if you have it all apart, you probably recognize it.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Re: Flywheel Lock
Postby tubasteve » Mon Dec 17, 2012 6:55 am
___Scott___ wrote:This worked well for me:
Interesting. Half inch gun works for me
tubasteve
Re: Flywheel Lock
Postby dkdmonk » Mon Dec 17, 2012 12:00 pm
I like this idea for my broken motor. My impact didn't loosen any of them.
Maybe Santa will bring me a new compressor :D
The other motor is on a stand and I haven't tried to remove the flywheel from it yet, I was going to get the timing belt work done first but figured I should get the flywheel off and delivered to the machine shop (I'm not in a big hurry either way).
I also liked this tool and the site looks cool!
http://www.handsontools.com/Klann-Tools%20...%20paign=BROI
Thanks for the help
dkdmonk
Images: 12
