Clutch Matchmarks to Flywheel
Postby Ironchief » Wed Dec 19, 2012 9:37 pm
I'm bolting on my clutch and the BGB says that there should be matchmarks on the clutch cover and flywheel meaning that the cover and pressure plate should be bolted on a certain way. Does it matter how the cover is put on? The clutch I'm installing is a South Bend clutch and I can't tell if there are match marks or not on it. There are two things that could possibly match marks on the cover, one is 3 dots in a triangle, the other is a single dot. Could this be them? I can't see anything on the flywheel though.
1990 CDM All Trac
Ironchief
Re: Clutch Matchmarks to Flywheel
Postby toayoztan » Thu Dec 20, 2012 3:22 am
Matchmarks are usually something you had to make before removing/disassembly, so you know it goes back on the same way.
Otherwise, just ensure that the holes are all lined up, etc.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
