My Axle Dilemma..
My Axle Dilemma..
Postby warracer » Tue Jan 01, 2013 2:36 am
Alright, I know for a fact that the 4 axle boots at the front have split and tear, now here its winter and I don't want to remove those @ -20C in the snow.
They don't click at all, there are in fact very smooth but I have to wait until spring to fix them
But heres my problem, knowing that I need to replace them, should I :
1. change only the 4 boots (arround 25$ each boot so 100$ aprox )
2. Change the 2 inner boots and get myself 2 Fensport outer axle kit (arround 300$ for all the parts)
3. Change the whole CV Axles. (250$ for jobber axle (DriveTechAmerica) , I can deal with a bit of vibration)
Option 3 seems like its the most logical thing ot do (in my opinion) and you guys must know better and thats why Im asking for your help and expertise
Also, if I change the whole CV Axles, I can't afford OEM (college budget) @ 620$ each, there is no way in hell im going to pay that . :crazy:
heres the CV I found : http://www.ebay.ca/itm/2-New-CV-Axles-8 ... 183wt_1163
Do you guys have better CV axles (complete) alternatives, like different brands and such, of course at a aisonable price
Thanks!
:D
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Re: My Axle Dilemma..
Postby toayoztan » Tue Jan 01, 2013 5:20 am
Get a shop to rebuild/overhaul your OEM axles?
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby warracer » Tue Jan 01, 2013 6:40 am
I don't have these kind of shop arround here sadly :(
____________
ST185H A-Spec:
warracer
Postby Rpz123isme » Tue Jan 01, 2013 6:51 am
On my 185 i replaced both axles through pep boys for 65 dollars a pop. napa also has them with better bearings but they cost about 95 each through them.
my pep boys axles held 280 whp with no problems!
Hesperia, CA
Rpz123isme
Postby warracer » Tue Jan 01, 2013 7:04 am
OH napa I have one of those next door ! Man I have to go see over there :D
____________
ST185H A-Spec:
warracer
Postby fussellbug » Tue Jan 01, 2013 2:31 pm
I would recommend contacting Raxles.com for a quote on rebuilt axles. I had my FWD axles rebuilt by them for about $175 each and they came back to me looking and feeling like new OEM axles. For rebuilds, they're the best company around. If they have a set of axles in stock to rebuild, they will send you axles with a core charge until you return yours, otherwise you just ship the axles you have and they'll ship back after rebuilding.
fussellbug
Images: 36
Postby Meenya » Tue Jan 01, 2013 3:10 pm
I bought OEM Boot kit for $35 for passenger side this past August comes with everything you need from 1stToyotaParts http://www.partswebsite.com/1sttoyotaparts/
Also local (to me) dealership sells OEM rebuilds, it was a bit more expensive than NAPA mentioned above.
Plenty of choices to choose from ;)
Mike
93 Turbo 4WD
91 GTFour RC
07 R6
Meenya
Images: 19
Postby underscore » Tue Jan 01, 2013 6:00 pm
I ordered boots for my rears from Lithia Toyota (OEM kit) that came with the grease and everything and to a shop to rebuild them. It's something you could easily do yourself if the axles aren't damaged yet.
Postby phattyduck » Tue Jan 01, 2013 8:35 pm
warracer wrote:Alright, I know for a fact that the 4 axle boots at the front have split and tear, now here its winter and I don't want to remove those @ -20C in the snow.
:D
If you wait until spring to fix the boots/axles.... they will be ruined and you will have to replace them.
Just get the axles from your local auto parts store. If they don't have them, get axles for an '88-'91 V6 Camry instead. They work just fine...
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Postby toayoztan » Tue Jan 01, 2013 9:17 pm
Yeah, that's kind of what I'm actually wondering.
Just how long have the boots been ruined/ripped?
It may be a safer bet to just get rebuilt axles or new ones.
I recommend Napa too, I never really have or hear complaints with their stuff.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby warracer » Tue Jan 01, 2013 9:37 pm
they have been ripped since 6 months I think, But I keep grease as much as I can in them, but just to be sure I think ill go with the Napa axle, Ill then keep my OEM one for future rebuild...
____________
ST185H A-Spec:
warracer
